01-23-2013, 10:52 AM   #1
Are there any tiny, good, cheap 50-ish lens for the Q
After using my Pentax A & M 50s on the Q, I'm finding it a good tele length. Thing is, I'd like a smaller, good & cheap lens in the 50-55 range. I've been looking at the Industars, but the M42 versions require a bulky adapter (I might as well use the K mounts I have with the Fotodiox adapter) and the M39 versions may or may not fit a standard M39 adapter because of the variations in the M39 mount for Russian SLRs that were different than the standard Leica M39s, which they also made.
Then there are the cheap C-mount 50s from Fujian & Fotasy. I know they get soft around the edges on micro 4/3rds cameras, but with the smaller sensor of the Q, how do they perform?
So... Any ideas for a cheap, small, good 50 or 55mm for the Q?
Cheers,
Bob :-)
01-23-2013, 02:03 PM   #2
Giiby, the m39 Industars made for the Fed (rangerfinder) series (NOT slr) will fit Leica Thread Mount adapter and is about as small as you'r gonna get..
The other option is the A110 50mm + 110->Q adapter which is def more compact but the total length will be about the same.
Either way you're looking at about $50 depending on the deal..
01-23-2013, 03:20 PM   #3
QuoteOriginally posted by digital029art Quote
Is there a way to visually tell the Leica from the slr version? A lot of them are advertised as m39 but don't say which version they are. Plus, I doubt a lot of the sellers know the difference .
01-23-2013, 05:01 PM   #4
Hello
I tested the Pentax K50mm f/1.2 and it give bad halos full open. Closed to f/4, it becomes good but you lose the aperture interest.
For the moment, my favorite is an old Sigma 50mm macro AF that give stunning results. A macro lens should be capable to out-resolve the tiny sensor. It is not so evident with other lenses, particularly low quality C-mount lenses.
adapter, camera, lens, m39, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, versions
Is there a small, cheap bounce flash for the Q? GibbyTheMole Pentax Q 17 05-20-2013 05:32 PM
Are the 135mm f1.8 lenses any good? Pepe Guitarra Troubleshooting and Beginner Help 11 03-16-2013 03:38 AM
Are Those $50 ebay Scanner Any Good violini Pentax Film SLR Discussion 5 10-24-2011 02:15 PM
Are these good prices for the 50-135 and Tamron 17-50? lmd91343 Pentax SLR Lens Discussion 4 10-19-2010 11:02 PM
Are there any cheap AF primes? Steve Beswick Pentax SLR Lens Discussion 14 10-23-2009 01:54 AM
All times are GMT -7. The time now is 09:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
