01-23-2013, 10:35 PM   #1
Q Shutter Setting Question
Hey guys,
New Q owner here, like many others out there with the recent discounts. I was playing around the camera using a Fotodiox K-Q mount adapter in Manual mode. I noticed that I cannot adjust the shutter speed to be slower than 2 seconds. With a regular Q lens it can go longer and also bulb mode. What am I missing here?
01-23-2013, 10:43 PM   #2
QuoteOriginally posted by ruggiex Quote
Hey guys,
You need a leaf shutter to go slower than 2 seconds, which only the Pentax adapter has.
01-23-2013, 11:13 PM   #3
Ah ok... I'm pretty noob when it comes to mechanics of camera but why is a leaf shutter needed? Couldn't the camera simply turn off the signal to sensor after a specific amount of time? I guess I'm wondering if there's technical limitation or if it's a choice.
01-24-2013, 01:11 AM   #4
Hi ruggiex,
If you need longer exposures with 3rd party adapted lenses, you can use Multiple Exposure Mode, set up a 2 sec exposure, and use up to 9 exposures for a total of 18 sec. Obviously, this isn't the same as a single long exposure, but it will work for some applications.
Scott
01-24-2013, 01:48 AM   #5
I think it's more of a choice honestly, to encourage people to buy the higher-end lenses and accessories. AFAIK the only thing that the leaf shutter is required for from a technical standpoint is the high flash sync speed (I believe it goes up to 1/2000s on the Q).
01-24-2013, 07:40 AM   #6
Thanks guys.
01-24-2013, 07:45 AM   #7
drougge's Avatar
It's a choice, but there is some motivation. Without a shutter they can't take a darkframe, and that means you get more noise. The sensor is definitely better than needing a 2s cutoff for that though, and I think it should be the photographer's choice if the noise is acceptable anyway.
camera, mirrorless, mode, pentax q, pentax q10, pentax q7, q10, q7, shutter
Q Shutter Lag? emergo Pentax Q 7 08-17-2012 07:43 AM
Camera setting too slow shutter speed Jed Mooar Troubleshooting and Beginner Help 6 08-09-2012 06:51 AM
setting Q Rusky40 Pentax DSLR Discussion 2 03-26-2012 03:39 PM
setting Q Rusky40 Troubleshooting and Beginner Help 10 09-13-2011 03:05 AM
k-x auto iso safe shutter speed setting? telly0050 Pentax DSLR Discussion 6 07-31-2011 02:30 PM
All times are GMT -7. The time now is 06:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
