Originally posted by stormtech Looking forward to your review and maybe some pics of this bag - looks perfect for the Q - and perfect for my BBA..............
Here you go - such as it is. Robtcorl also uses this bag and I think he's the one who first linked to it (I wrote I couldn't find the thread).
When I got my K-01 last winter I called Pentax USA Customer Service asking for advice on a bag for the (then) new camera. The intrepid representative on the other end of the telephone recommended this bag, assuring me it would be a perfect fit, so I bought two for $9.95 each since shipping cost more than one bag alone. Alas, the K-01 won't fit through the throat of the bag, even without a lens mounted.
The bag itself is Genuine Leather - there's even a little leather tag attached to a strap ring to remind us of that fact. It actually is a nice, supple embossed grain leather dyed black. The material is neither so thin as to risk a tear nor so thick as to feel stiff and heavy. Stitching appears straight and strong throughout the item, so that it seems a much higher quality than its price suggests. There are several small features designed into the bag and the necessary hand sewing operations to provide them make it an excellent value.
The bag is petite, just like a Q.
Taking our Que (
) from the orientation of the red Optio letters embossed into the top and Pentax logo on its flap, the front of the bag has a full-width patch pocket with a hook-and-loop closure. The back, then, has a belt attachment patch stitched on. The loop appears large enough to allow a 2" belt to pass through. In this orientation, if you carry the bag on your belt, the top opens away from your body for convenience and safety. A small tab facilitates opening the top. The patch pocket has enough depth to hold slim objects such as an extra battery, SD card or lens/body caps, but not much else.
The interior of the bag is standard dark gray flocking, thick and pdded enough to protect against ordinary bumps and jostles. There is one small removable divider and a removable stiff, covered baseboard for stability such as are found in expensive camera bags.
Sewn into the top across its width there is a traditional mesh pocket. The bound elastic edge is tight and holds the mesh firmly closed. The expandable mesh seems suitable for more dimensionally shaped objects than would fit the outer pocket.
The bag includes a strong woven nylon strap with durable metal nautical swivel clips that attach to D-rings sewn firmly into the bag ends in a double-bound pattern. To my eye, the strap alone could sell for $9.95 in any camping or rigging catalog.
With the 02 5~15 Zoom mounted (one of the longer Q lenses to date) the Q can be stored face down for easy retrieval and something else stored in the smaller adjacent space. In this orientation the top zips closed comfortably without placing any strain on the camera or the bag. A user who owns, for instance, the 01 and 06 Zoom could store the 06 in the small space with the 01 mounted (and the Q would sit a bit lower in the large space).
As a final note, when I received the bag(s) I was shocked to discover they were stuffed with stiff paper to maintain their shape (as an expensive purse would be - ask my wife) and packed in a plastic sleeve for protection.
In my opinion this Pentax Optio gadget bag will serve a Qser quite well - and
should be purchased on its merit and held for whatever use presents itself at some later date, just on the basis of sheer value.
The
PTX-L80 Optio Gadget Bag is available from the Pentax Webstore @ $9.95 each
HERE
Respectfully submitted,
monochrome
