01-25-2013, 04:50 PM - 1 Like   #1
Adapter/lens loose fit fix
I contacted Fotodiox about my OM to Q adapter having a loose fit. Here's the response I got from Fotodiox Tech Support:
"This is something that can happen with the adapters (sometimes right out of the box if the factory didn't position them right), the movement and looseness of the lens is due to the spring mechanism that’s used to hold the lens tight to the adapter. The 3 flanges in the middle of the adapter (that the lens locks onto) are split open slightly, this gap is what gives the tension that holds the lens tight to the body.
Over time and use this gap can decrease in size (or in your case, the factory just didn't open the gap enough), what can be done is to get a slim metal object (a flat eyeglass screwdriver is ideal) and insert it into the slit to open it up just a little bit (see attached image, make sure to do it to all 3 evenly). The more you open it up the tighter the lens will be to the adapter, too much and the lens will have a hard time mounting so make sure to do it just a little bit at a time, it doesn't take much at all to get a tight fit".
This easy fix worked great on my adapter. Now I don't have to send it back!
Lacro
NIKON D700  Photo
01-25-2013, 05:11 PM   #2
Thanks for contacting the company and posting a quick fix. Job well done. You are going to have a lot of fun now! The Q is great fun.
thanks
barondla
01-25-2013, 05:49 PM   #3
Not a Number's Avatar
That's a fix I had to apply to a cheap glassless Minolta MD to PK mount adapter. Some lenses are more snug then others and I have to repeat the procedure after using one of the very snug ones.
One of my old Kiron teleconverters has "springs" similar to those but one end is cut free so it is more of a finger. Either the metal is better or that design works better because I've never had to bend the "fingers" to get more tension.
The better teleconverters and adapters use actual steel springs as in the camera mount.
Thanks for sharing this simple fix.
01-27-2013, 07:46 AM   #4
Hrm, I wonder if that works on the Q flange as well...
Charles
adapter, bit, camera, factory, gap, lens, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, time
How to fix a loose front lens? kawaist Troubleshooting and Beginner Help 6 10-08-2013 12:25 PM
Lens loose with genuine M42 adapter...fix? ryan s Pentax Camera and Field Accessories 22 09-18-2013 12:36 PM
Yashica 55/1.2 loose mount, M42, how to fix? hoanpham Pentax SLR Lens Discussion 10 10-29-2011 03:30 AM
Pentax MX with M42 Adapter - Cannot fit 21mm lens MarieDJ Pentax Film SLR Discussion 9 08-27-2011 06:13 AM
Pentax Lens will not fit into m42 adapter! Please help! alfie_mint Pentax SLR Lens Discussion 13 08-14-2011 01:04 PM
All times are GMT -7. The time now is 07:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
