01-28-2013, 07:33 PM   #1
Tight Fotodiox adapter
My wife's Fotodiox adapter showed up today and on the lens side, that sucker is tight! I stuck a lens on it & it took a bit of brute force to get it off. I know you can tighten them up as per this thread, but what about loosening it a little? I'm not mounting a plastic mount lens on it for sure, 'til I get it loosened up.
What about just leaving a lens on it for a few days? Could that compress the spring & maybe loosen it a little?
Cheers,
Bob :-)
01-28-2013, 07:43 PM   #2
crewl1's Avatar
Mine was tight like that on the lens side when I got it
After using it for a while it loosened up.
Try taking a lens you are not to concerned about and attach/detach it a few times.
01-28-2013, 08:10 PM   #3
For mine, if I look at the adapter by itself and press down on the release latch from the edge, the pin does not retract all the way. I kind of have to stick my finger in a bit more and try to press the latch down directly perpendicular to the pin in order for it to retract *almost* completely and that makes removing lens a lot easier. However, it is so tight with my 1.5x converter that I need to stick a small screwdriver in there to retract the pin completely in order to remove the converter! I was almost in panic mode the first day I put the converter on it.
01-28-2013, 08:19 PM   #4
After testing all my lenses this weekend I found the plastic mount ones MUCH easier to remove. I also found that pushing the release pin and turning a tad toward tighten before turning it toward off helped it give up its grip on tighter lenses. It helped the pin release easier.
01-28-2013, 08:25 PM   #5
On my wife's the release button works ok, the spring is just tight. I worked it & it is starting to loosen up. I just didn't want to wreck a lens on it.
Cheers,
Bobbo :-)
01-28-2013, 08:55 PM   #6
stormtech's Avatar
My Fotodiox adapter is now without the locking pin. After a near heart attack when I couldn't remove my DFA 100 WR, it's gone now.
01-29-2013, 04:15 AM   #7
tux
yeah I made sure I put my cheapest lens on it 1st !! Mine was tight but not over tight.
01-29-2013, 05:33 AM   #8
robtcorl's Avatar
Mine is starting to loosen up.
I'm sure that I didn't have the first few lenses I tried even locked in all the way, it was so tight, and I was so afraid.
01-29-2013, 06:48 AM   #9
hnikesch's Avatar
Mine seemed just right from the get go no problems with the pin or removing a lens, just lucky I guess
Hans
01-29-2013, 07:38 AM   #10
QuoteOriginally posted by hnikesch Quote
Mine was fine from the start as well. Wife's adapter is ok now. Gotta paint it as soon as the weather cooperates.
adapter, camera, fotodiox, lens, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Fotodiox adapter question GibbyTheMole Pentax Q 60 02-10-2013 08:07 PM
What is Focal Length of Fotodiox Q to K adapter? SonDa5 Pentax Q 4 12-25-2012 03:11 PM
For Sale - Sold: Fotodiox Q-K adapter crewl1 Sold Items 0 12-05-2012 02:09 PM
For Sale - Sold: FotoDiox K-mount to m43 mount adapter w/ aperture control deejjjaaaa Sold Items 3 08-04-2011 10:06 AM
All times are GMT -7. The time now is 07:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
