Originally posted by tclausen Q: how do you enable focus peaking on the Q? I was given to understand that it was not available there....Can it be made work with the non-AF lenses?
You can turn it on and off via the menu, go to the Focus settings options where you can also configure the focus assist magnification ratio.
For adapted lenses and 'Toy' lenses you need to press the OK button to turn on the focus assist.
Peaking will either be always on or always off depending on your choice.
As Kivis stated you have to update the firmware to get focus peaking.
