Originally posted by drougge Sure I do. And it works fine too. On a tripod of course, but many compacts give crap results under the same circumstances. (The Q is a bit limited by the 2s max shutter time with lenses without shutters, but if you have a shutter it's fine. And many night shots are ok without shutter too.)
Fair point. I should have said, "does anyone expect the Q to be a high ISO camera?" If you can use long enough shutter speeds/low enough ISO, then the Q works fine at night.
It should also be noted that the Q has much nicer high-ISO grain than many cameras. In a way, this makes it more usable at high ISO than it would otherwise be.
