02-19-2013, 04:47 PM   #1
colonel00's Avatar
Autofocus on adapted Pentax lenses that have an SDM motor
Please help a noob understand something. While showing the girlfriend how cool it was to mount my DA 18-135mm lens on the Q she asked the simple question that I just don't have an answer for. So, why can't auto-focus be used on an adapted lens that is a K mount and has an internal motor? I have done some searching around but can't find a clear answer. It has to be more to it than just having the correct "pass through" contacts doesn't it? Does it have to do with not "knowing" the lens and having the programming to control it properly? If so, would't that just be a few more contacts and a firmware upgrade? I do understand that the niche of using adapted lenses on the Q is fairly limited so perhaps there is just no motivation for Pentax to make it work? Thanks.
02-19-2013, 04:51 PM   #2
jpzk's Avatar
I would start here:
https://www.pentaxforums.com/forums/pentax-q/209474-adapted-lenses-tested-q-r...ce-thread.html
and that is a good question you are asking as I also have a couple of SDM-lenses;
I know that there is a post(s) somwehere in that thread about the DA*300/4 (SDM) .... I haven't checked it out yet.
JP
Edit: here's the post about the DA*300/4 ... https://www.pentaxforums.com/forums/pentax-q/209474-adapted-lenses-tested-q-r...ml#post2215855
and one more here (post 242): https://www.pentaxforums.com/forums/pentax-q/209474-adapted-lenses-tested-q-r...ml#post2268701
Not sure whether this will answer your question but someone more knowledgeable will surely jump in with the proper answer.
02-19-2013, 04:55 PM   #3
crewl1's Avatar
I think it could also be the amount of power needed, as the Q is already starved just trying to power itself and the native AF lenses.
The engineers probably determined the little Q battery could not handle it.
(Why not a battery in the adapter? Or a solar powered one for daylight use?)
02-19-2013, 04:56 PM   #4
jpzk's Avatar
QuoteOriginally posted by colonel00 Quote
See Crew's1 post just above.
That would make sense.
JP
02-19-2013, 04:58 PM   #5
boriscleto's Avatar
Sony doesn't have a reliable AF A to E adapter either. They have a $200 adapter that doesn't AF, and a $400 adapter that adds an entire mirror assembly and phase detect AF sensor.
02-19-2013, 04:59 PM   #6
The adapter has neither the necessary power contacts or data contacts needed to enable AF on adapted lenses. Plus, even if AF were enabled, it would be very very slow due to the CDAF, so I don't think you're missing out on much!
02-19-2013, 05:00 PM   #7
colonel00's Avatar
QuoteOriginally posted by jpzk Quote
I would start here:
JP
Thanks. I have been following that thread closely and enjoy what people are doing with all of the lenses. Still though, even with the official Pentax adapter, auto-focus is not an option.
QuoteOriginally posted by crewl1 Quote
Now this is a very interesting point and thanks for chiming in. I had not thought about the power requirements. Does the Q really struggle that much with its native lenses? I have not had mine long enough to get some good time on with it.
02-19-2013, 05:09 PM   #8
colonel00's Avatar
QuoteOriginally posted by boriscleto Quote
Thanks. Perfect answers I was looking for. Once I had the right search terms it was easy to find the answers by looking up the Metabones product for the Sony Nex. Right at the bottom of the page about the Canon lens to Nex body adapter page it states it pretty clearly:
Autofocus
Autofocus is supported, with the following known limitations.
Autofocus speed is very slow and inadequate for most moving subjects. The autofocus speed is unfit for professional use for sure, and it would disappoint most enthusiasts.
02-19-2013, 05:20 PM   #9
crewl1's Avatar
It doesn't struggle but it eats up batteries quicker than other cameras. It is recommended to bring extra batteries on a photo outing with the Q.
camera, contacts, lens, lenses, mirrorless, motor, pentax, pentax lenses, pentax q, pentax q10, pentax q7, q10, q7
Lenses that won't autofocus on the K-01 Designosophy Pentax K-01 28 03-17-2013 08:41 AM
Help a noob relate the reach of a spotting scope to that of an adapted Q colonel00 Pentax Q 8 01-18-2013 03:48 PM
Dumb Question: Adapted Leica lenses on film bodies? Why not??? DanielT74 Pentax SLR Lens Discussion 10 10-26-2011 12:05 AM
Will Pentax Release DA* II lenses with DC motor instead of SDM mikemike Pentax SLR Lens Discussion 6 10-14-2010 07:24 AM
Autofocus lenses on an ME Super cruro02 Pentax Film SLR Discussion 5 01-11-2009 07:07 PM
All times are GMT -7. The time now is 09:51 PM. | See also: NikonForums.com, part of our network of photo forums!
