Show Printable Version 94 Likes Search this Thread
09-10-2017, 04:21 PM - 4 Likes   #91
kwb
With Q7, SMC PENTAX MACRO 1:4 50mm and PENTAX K-Q adapter.
Jumping spider feasting on crane fly by k kwb, on Flickr
09-10-2017, 05:20 PM - 1 Like   #92
baro-nite's Avatar
Good catch, both you and the spider!
09-21-2017, 08:29 AM   #93
Unregistered User
Guest
Pentax 03 lens @ minimum focus (about 1 inch):
IMGP4123
09-21-2017, 11:41 PM   #94
kwb
QuoteOriginally posted by Cipher Quote
Good sharpness and color, good job!
03 is the most closeup-friendly of the native Q lenses I own (03>02>08>06=01 in terms of maximum physical magnification).
09-22-2017, 07:06 AM   #95
Unregistered User
Guest
QuoteOriginally posted by kwb Quote
Thanks!
It really gives a unique perspective, doesn't it?
The bee image is pretty much SOOC, a little sharpening and vibrance added. I shot it on a Q7 with a strip of paper over the contacts, to get a little more coverage.
09-22-2017, 11:48 PM   #96
kwb
Yes, interesting perspective indeed!
If you're post processing anyway, why shoot in jpeg? I guess that's why you need to cover contacts, to prevent Q7 to automatically crop a little when producing jpeg?
09-23-2017, 07:04 AM   #97
Unregistered User
Guest
Right. Even if you shoot in RAW with the 03 on the Q7 it will autocrop to fill the frame. It isn't a big deal, but you do get a little more coverage and can easily clone out the corners.
I almost always shoot jpegs, with minimal camera sharpening, always sharpening in PP. I've never been able to justify the time or storage requirements that RAW demands for the results I get. If the lighting is particularly bad I will shoot RAW once in a while for more control of color temperature.
09-23-2017, 12:17 PM - 1 Like   #98
kwb
Hmm, I was quite sure that the DNG file contains all pixels without cropping from my experience with RawTherapee some time ago, but nowadays I use Lightroom, I looked at one of my files and sure enough, it seems to be auto-cropped. But using RawTherapee it's not.
Attached are screen shots of embedded jpeg, Lightroom and RawTherapee in this order.
What's going on here seems to be that the DNG contains full pixels as well as cropping information, and Adobe products honor that to autocrop and stretch, but RawTherapee doesn't. I don't know how to bypass auto cropping in Lightroom, so if I want to get the full pixels maybe I also need to cover the contacts.
PENTAX Q7  Photo
PENTAX Q7  Photo
09-23-2017, 12:55 PM   #99
Unregistered User
Guest
I didn't know about RAW Therapy. I just use Photoshop.
Great examples, that's exactly the kind of lighting situation where I would use RAW.
09-23-2017, 09:15 PM   #100
kwb
Thank you.
09-24-2017, 01:01 PM   #101
Do you cover all the electrical connections?
Anyone know if SilkyPix, packed with the Q, auto crops in Raw?
Thanks
barondla
09-24-2017, 01:38 PM   #102
Unregistered User
Guest
QuoteOriginally posted by barondla Quote
Thanks
barondla
I cut a piece of paper in a "c" shape somewhat bigger than the row of contacts, then, with the camera body on its back, mounted the 03 lens. You have to enter 3.2 on the opening screen to enable SR properly.
I've never used SilkyPix, so I don't know.
It seems to me that the non-auto cropped image has a little more resolution than the auto crop, at least towards the edges, in addition to giving more coverage. Here is a cropped image (not auto cropped) from the 03 that is also on the "Insects" thread:
IMGP1295
Front element was about 1 inch from the bees, I shot at ISO 800 to freeze motion. Looks like lens and sensor resolution limits are pretty close to each other, you could probably get a little more at ISO 200 but then the bees' motion would show up.
09-24-2017, 05:34 PM   #103
Superb dual bee shot! Very impressive quality. Like the dramatic look.
Thanks for the info Cipher. Tried the c paper and it worked fine on the Q7/03. Not surprised the uncropped has more resolution. Cropping throws away pixels. Original Q is probably sharper than the Q7 in crop mode with 03.
Thanks for sharing
barondla
09-24-2017, 06:00 PM   #104
Unregistered User
Guest
Thanks for sharing
barondla
Flickr erodes some IQ too, the original file is even better. That dramatic look the 03 gives in extreme close-ups would be hard to duplicate with any larger format sensor, and certainly not hand-held. The 03 may only be a "toy" lens, but what a great toy!
09-27-2017, 10:51 PM - 1 Like   #105
kwb
I checked today and SilkyPix auto-crops when loading DNG, but you can revert it back.
Click "trim" button (scissors icon at the top), then press "Enable all data including invalid area in RAW data" button at the bottom right of "Setting for trimming" window.
10mm, advantage, aperture, camera, distance, flickr, k-5, lens, macro, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, series, shirt, tube, vivitar
Is the field of view for the DA40mm the same as the'M' version DaveHolmes Pentax SLR Lens Discussion 7 06-06-2011 12:59 PM
All times are GMT -7. The time now is 09:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
