02-25-2013, 10:34 AM   #1
Issue With Q and OEM Adapter
We just got our K-Q adapter in a few weeks ago and initial tests with the 15mm Ltd were very good. Everything seemed to work as normal. Then last weekend we took the Q, adapter, and kit lenses (18-55 and 50-200) on a weekend trip and started encountering issues. The Q seems to work fine with the 01 lens, but with adapted lenses I was only able to take 1 or 2 shots before the shutter clicked and stayed closed. The screen still displays information but the screen is dark otherwise. The only remedy is to shut the camera down and turn it on again, which needs to be repeated every few shots.
The Q firmware is version 1.10 and there doesn't appear to be any physical damage to the adapter (aperature opens and closes smoothly). The problem first appeared when using the camera outside in temperatures around 1 or 2 deg C, but still happens at room temperature (although it required 5 or 6 shots to appear in the latest test, which was conducted with a partially depleted battery). It exhibits the issue with both the kit lenses and the 15mm.
Has anyone encountered an issue like this?
02-25-2013, 12:08 PM   #2
QuoteOriginally posted by polachekphotography Quote
i experienced the same issue...the adapter was defective and had to send it back...the new one works great!!. nothing to do with firmware
02-25-2013, 12:11 PM   #3
you can look at pictures of what it looked like when it got stuck
https://www.pentaxforums.com/forums/pentax-mirrorless-camera-discussion/21301...adapter-2.html
02-25-2013, 12:22 PM   #4
crewl1's Avatar
Yup, Amy is the expert on this one, send it back.
02-25-2013, 12:33 PM   #5
QuoteOriginally posted by crewl1 Quote
unfortunately
02-25-2013, 01:11 PM   #6
Looks like I should have done a more exhaustive search because that's exactly the same issue! Thanks Amy and crewl1 for the responses.
02-26-2013, 10:56 AM   #7
ChrisJ's Avatar
I believe SRS here in the UK had issues with the first batch, all is well now.
Chris
02-26-2013, 07:49 PM   #8
northislander's Avatar
Mine does the same thing but I can live with it. I find it helps if you keep the adaptor all the way open or closed when starting up the Q.
adapter, camera, kit, lenses, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, screen, shots
problem with my q or pentax adapter???? pearsaab Pentax Mirrorless Cameras 31 08-02-2014 04:02 PM
Q handheld with K adapter? Szenario Pentax Q 15 02-21-2013 02:37 PM
Q OEM vs Fotodiox adapter opinions robtcorl Pentax Q 21 02-19-2013 06:52 PM
Pentax OEM Q to K adapter in stock Docrwm Pentax Q 15 11-16-2012 09:20 PM
Q to K adapter and macro. i83N Pentax Q 4 09-18-2012 10:45 PM
All times are GMT -7. The time now is 08:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
