Originally posted by drougge Then I suspect he should have stopped the K10 down more (or the Q less). At far distances f/3.5 on the Q should be the same as f/13 on the K10, at close distances the difference is smaller, but probably not as small as in this test. More diffraction on the Q at 3.5 than the K10 at 7.1 at any rate.
You are probably right but I don't think the OP was even attempting to test his gear that adhere to any standardized method. He compared the DOF of Q+01 at f3.5 and the DOF of K10D+35 Limited at f7.1 and deemed it similar for his needs. Yes, the test is flawed in too many ways, rendering the results more or less useless but still his blog was an interesting read.
