Originally posted by baro-nite Interesting -- photozone found f/4.5 sharper than f/5.6 even at 15mm. I'm wondering if it is a case of contrast vs. sharpness.
I don't blame you for questioning. You be the judge. I actually shot the sequence twice because the first time around the varying lenses tested caused color balance shifts in AWB (I should have anticipated that), so then I went with the 5,000 degree WB setting. I don't think there is much question here, at least based on my sample of the lens. I greatly respect Photozone testing, but on this sample I think it is clear I got it right. Not only sharper, but CA around the rabbit ears is much better stopped down (and I do tend to favor images that might be just a tad softer if CA is objectionable). In RAW, I find it much more difficult to clean up CA from adapted lenses on the Q sensor compared to conventional images in LR (not surprising).
Remember that I'm shooting at just over 2 feet. I plan to shoot this unaltered studio test all the way up to 200mm, so these closest shots have to be closer than I would like (my basement can only accommodate a finite distance!). That said, I suspect the results would be pretty similar at 15 feet.
1) 5-15 f/4.5 (AWB)
2) 5-15 f/5.6 (AWB)
3) 5-15 f/4.5 (5000 WB)
4) 5-15 f/5.6 (5000 WB) - this version is posted elsewhere here for comparison (re-posting not allowed) -
https://www.pentaxforums.com/forums/pentax-q/209474-adapted-lenses-tested-q-r...ml#post2299949.
