Originally posted by sledger Anyhoo - back on (my) topic regarding the Q and best video settings..
So far my personal best results have been by using;
Tripod mounted Q
SR off
F3.2 to F5
Multi-segment metering
AF with Spot focus
Is this about it?
Video is a lot more complicated than shooting stills, and I am far from being an expert, but the quality depends a lot on the the resolution you set in camera.
You can't expect the video quality to be the same as stills as even the highest video resolution on a Q is 1920 pixels X 1080 pixels, around a third of what you get with stills.
Video is further complicated by the file type, the Q gives you .MOV format which is not a ready to run video, though some video editors can convert on the fly so it appears to be. The .MOV format, as I understand it, is just a container for the video frames, to run and export it as a video format file it has to be converted into a streamable format such as MP4 or similar, a format that has the built in ability to show you the frames one after the other at the frame rate you set, which will often degrade the resolution even further.
If you export the video to YouTube it sets the resolution even lower for bandwidth and file size reasons, Vimeo imposes less restrictions.
My video of the Moon on YouTube is definitely not the same as I can view it on my computer or even my TV, not even close.
And I haven't gone into other considerations such as bit depth and Mp/second which gets even more complicated. Rest assured that your Q can show you all that your monitor and TV is capable of, albeit at the lower resolution.
Any video experts out there?? I, for one, need one.
Chris
