03-04-2013, 08:02 AM   #1
Distortion correction on the 02 zoom
I'm thinking of using the Q & 02 zoom to do some copy work. Specifically, album covers of LPs I'm ripping into the computer for digital playback. The reason I'm thinking of using the Q is because of the in-camera correction on the 02 lens. Does the in-camera correction do a good job of fixing pincushion distortion with the 02 zoom?
Cheers,
Bob :-)
03-04-2013, 08:58 AM   #2
panoguy's Avatar
You could turn it off and on (via Menu->Camera->2->Distortion Correction) and actually see the effect it has. The LCD "live view" shows distortion correction on the Q.
03-04-2013, 03:26 PM   #3
hnikesch's Avatar
QuoteOriginally posted by GibbyTheMole Quote
Cheers,
Bob :-)
You can improve the in camera results with PS Elements camera distortion correction filter, It's quite powerful
Hans
03-04-2013, 03:33 PM   #4
ChrisJ's Avatar
Both Photoshop CS6 and Lightroom 4 have distortion corrections for most Pentax Lenses (And most other makes too), including the Q 01, 02 zoom and 06 zoom, built in, the default settings will correct to zero distortion. Note for some extreme wide angle lenses such as fisheye's and the Q 01 8.5mm it will have to crop slightly to remove all the lens distortions.
Lens correction is in the Raw Converter (the 6th icon from the left), check the 'Enable Lens Profiles' box and it should recognise the lens from the EXIF data, if not select Pentax in the manufacturer box, and the lens you want from the drop down menu below that.
When copying your camera has to be dead centre and square onto the picture to be able to correct to a totally flat field. The above won't correct for the distortion caused by an angled camera, but you probably know that.
Chris
03-04-2013, 06:20 PM   #5
Thanks for the tips, gang...
QuoteOriginally posted by ChrisJ Quote
Yep. I only have LR3 and a prehistoric (but still very useful) PS7, though.
camera, correction, distortion, in-camera, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
For Sale - Sold: Pentax 02 Zoom Lens for the Q Brazeal Sold Items 2 01-18-2013 09:01 PM
Sports Golfing with the Q and 02 Zoom LaurenOE Post Your Photos! 5 01-03-2013 10:14 AM
Distortion correction on K-x - am I wrong to not be impressed? Unsinkable II Pentax DSLR Discussion 8 05-14-2010 04:11 AM
Automatic lens distortion correction example PentaxPoke Pentax SLR Lens Discussion 6 02-03-2009 05:39 PM
Geometric/distortion correction in Photoshop dazman Digital Processing, Software, and Printing 4 09-10-2008 05:02 PM
All times are GMT -7. The time now is 08:49 PM. | See also: NikonForums.com, part of our network of photo forums!
