Originally posted by audiobomber How would a Q with DA*300 compare to a new superzoom bridge camera? Some of them go to 1000-1200mm equivalent fov. I'd be interested in test samples under similar conditions.
How about Q with DA*300 vs K-01 with DA*300 and a good quality TC, cropped? I'll be joining a bird-watching group this month and I'm thinking I'll need some range. The adapted Q is a possibility, but I'm held back by ISO performance. It's sometimes impossible to get a decent shutter speed at f4 with a low ISO.
I don't have a super zoom bridge to compare. If someone in LA wants to go out and do some comparisons I would be happy to oblige.
I have found the Q + DA*300 combo to be really good.
You will need a solid tripod so slow shutter speeds are not an issue.
I could not use the combo hand held.
You will not be doing BIF photography with this combo.
One of the toughest things you will find with this combo is actually getting the distant bird in frame, so a few of us have found a red dot sight to be indispensable.
A cropped K-5 with a 300 2.8 +TC shot may be better, but cost and weight is a factor.
Crops from 500mm lenses like the Sigma 4.5 are very good also.
Also, you might get AF with that combo, which you won't with the Q and DA*300.
