Manfrotto Unica I Quote: Model: MB SM390-1BC:
Outer Dimensions: 15 × depth 34 × height 26cm width
Inside dimension: 12 × depth 28 × height 20cm width
0.52kg: Weight
Recently for my birthday my wife got a new Pentax Q-10 for me. What a great little camera! Well, next comes where to carry it. Since it is a rather small camera, it fits fine in my current messenger bag, but the protection that I wanted wasn't quite there. I am replacing my Knog Leading Dog bike/messenger bag. So, after much consideration, I looked at several bags. I really do not like big and bulky bags. I wanted something that was similar in size to the messenger that I carry now and this one fit the bill. Overall, it is the same length as my previous bag but the with is slightly larger so this was a good fit. Manfrotto is a great company and they have a really nice line up on bags. Problem is that they are mostly all too big for what I need, with the exception of this one. And this one is hard to find. According to Manfrotto, and everywhere I looked, all I saw in the Unica line was the III, V, and VII. All of which are huge!! Then I stumbled on the Unica I. Saw a video of it for the Asian market, HK I believe.. Anyway, I looked, and sure enough, the Japan market has the Unica I version. Which is the smallest in the Unica line up. Since my Q-10 is so small, and my requirements for a not so large bag, this was great.
The bag itself is very durable. It is made of a water repellent nylon and feels very solid. The velcro is very strong as well. It has a very sturdy metal clasp just to keep things in place. The inside has lots of room as well. The removable separator on the inside had two parts. The one you see on the right of my bag, was I suppose for the main camera. And the one on the left was meant for the top part of the camera, however, to make it a little more useful, I turned that cover separator into another side separator. I think it works better this way, and I can still use the red flap to cover the top of the camera. So, win, win.
There is also a rear pocket that can fit a small netbook or in ipad. The outer most zippered pocket has several storage options. I currently am using it for just daily things. The black pocket labeled(pocket) is technically for Manfrotto's pocket tripod, which I will be getting soon. Also, everything is accessible from the top by zipper for easy access. so you don't have to open the strap and lift the cover every time you need to quickly get in the bag. This was a big buying point for me, as I constantly have to take the train here in Tokyo, so getting in at my wallet for my train pass is much simpler this way. Before, I would have to lift the flap every time with my previous bag.
Basically my uses for this will be an everyday bag, so the open space you see to the left of the photo will be for my wallet, phone, etc... Still with enough room for camera and spare lenses.
Since the Q-10 is an interchangeable lens camera, however small, the Unica I has just enough room for what I needed, and just enough for a couple extra things I carry on a daily basis. Currently I only have the (02)regular zoom, and (06)telephoto zoom. It has ample room for a lens on the camera and if I wanted, all 4 other of the Pentax Q lens lineup would have no problems fitting in here.
I also wanted a little protection for my lenses, so I opted to get a little storage case to fit inside the bag for my lenses. I went with the
Nano III camera pouch. I know it is a little extra work to get the lenses out, but to me, the added security of the lenses being in one place and not just bouncing around was worth it.
It was a great size for two lenses side by side and has a nice pocket for memory cards or in my case, a remote.
Again, just as durable as the Unica, and a great match to the Unica. The Nano III was a great choice.
Nano III camera pouch Quote: Model: MB SCP-3BC
Inside dimension (height × width × depth): 11.5 × 4.5 × 7.5cm
Outer dimensions (height × width × depth): thirteen × 5.5 × 8.5
Weight: 0.1kg
