hi
i was looking forward to using the anti-shake feature of the Q and the firmware update went through fine. for several days i tried different lenses and entered different focal lengths.
however today i noticed that the anti-shake option is grayed-out and and turned off. i haven't made any major menu changes but trying to change settings to get the anti-shake back haven't worked.
i also noticed two things:
1) after i turned the camera on after updating the firmware, everything was reset back to default, including time and date among other things. is that normal?
2) every time i start the camera the focal length setting is there waiting for a selection. i've been hitting OK because i selected a lens to use and left it on the camera and its the only way i know to get past that menu. is it normal to have to enter that info every time?
do you think my firmware update went through correctly or should i do it again?
thanks for any help!
krem
