I found it particularly helpful when Adam listed optimum settings for new K-01 users. I'm not sure we have a similar resource for the Q.
Two items are of particular interest to me.
First, I'd be curious how often anyone uses highlight or shadow compensation. I shy away from it on the Q because I hesitate to use any higher ISO than is necessary on the small sensor. I don't worry about that at all on the K-01 in high contrast settings.
Second, I wonder how auto-NR works. My assumption is that it uses low-level smoothing in the low ISOs, and then high-level is triggered at a certain ISO point. However, if it is more sophisticated than that - and auto-NR uses less smoothing at ISO 125 than you get by going with the low-NR setting at that ISO - that would be a far better situation. Obviously, for RAW shooters most of us want to control the amount smoothing and start out at no smoothing or a minimal amount.
