04-12-2013, 05:05 PM   #151
QuoteOriginally posted by pickone Quote
Thanks, I tried to use it using the instructions but I can't get it to update to anything, it does not recognize the updates. My files are downloaded as zip files, tried unzipped and zipped, and I have followed the the instructions of formatting a new card and hitting the right arrow once you see the version you have on the screen and nothing happens
1) Download file. Double-check it is the right one. (It isn't for a lens that isn't on the camera or a different camera.
2) Unzip it. The .bin file is the one you want
3) Copy file to SD Card -- *root* directory (no sub-directory, so if your card is G:, then it should appear at G:/firmwarefile.bin, not at G:/DCIM/firmwarefile.bin or anywhere else.
4) Put the card in the camera. Make sure you have a fresh battery installed.
5) Turn on, go to firmware menu, right arrow, blah blah -- it should be obvious at this point...
04-12-2013, 05:21 PM   #152
VisualDarkness's Avatar
You need to run the unzipped file to unzip the actual firmware if its an extra zipped one.
04-12-2013, 06:17 PM   #153
Sorry... maybe I should have unzipped it first & just uploaded the .bin file. :-/
If you keep having issues, let me know & I'll do that.
04-12-2013, 08:46 PM   #154
Could you do just the bin file because I have a bigger problem that I a program called VLC has corrupted a lot of my files. It has renamed it as VLC media file along with a bunch of other files. Deleted the VLC program, tried to remove file associations in regedit but still the problem exists. If I had the straight BIn file it might help, thanks.
04-12-2013, 08:47 PM   #155
QuoteOriginally posted by GibbyTheMole Quote
The KX and the Q are my Pentax cameras too.
04-12-2013, 08:57 PM   #156
It hasn't corrupted them, it just thinks it is a media file and is trying to play it. VLC will not alter your files. Just do a straight copy from the hard drive -- don't try to "open" the file...
04-12-2013, 09:41 PM   #157
I am not try to play it, I just unzip it and it says it is a VLC. bin file, I copy it to the card and the camera acts like it is not there. I am on the page which shows the 1.00 version and I hit the right arrow and nothing happens.
04-12-2013, 09:44 PM   #158
Yeah, seems like you are copying it to wrong place. In any case, VLC has nothing to do with it -- .bin is a registered file type for that player and so the icon will be that, but it means nothing and affects nothing. (I also have VLC, and no troubles with my firmware files.)
Are you copying direct to camera with USB cable, or do you have a card reader on your computer, copying it there, and then putting card in camera?
04-12-2013, 09:46 PM   #159
I am copying to a new formatted by camera SD card, should I use the USB cable?
04-12-2013, 10:01 PM   #160
No, straight copy is easier.
At this point we need to ask some really stupid questions to cover the basics, so I apologize:
-- You have a plain Q, right, not a Q10?
-- The filename of the file you are copying ought to be: "fwdc601p.bin" Right?
-- You ARE putting the card in the camera after you copy it, eh?
When you go to the firmware menu, if it can't find a proper firmware file, it will look like pic#1 below (expect yours will say 1.00 instead of 1.11). If it does find a file, it will look like pic#2 below, and you can hit the right arrow to go to update screen. Which screen does yours look like?
04-12-2013, 10:14 PM   #161
a plain Q, the right screen, that is the file I am copying to the card and putting in the card door before going to the shown screen. I tried plugging the camera in but it turns off after a few seconds so the card must be the way to go.
04-12-2013, 10:33 PM   #162
It finally worked, I did a drag and drop rather than a send to from the download file, nothing different, thanks a lot 1:30 am, time to go to sleep
04-12-2013, 10:38 PM   #163
Send to? Yeah, don't use that....
04-15-2013, 11:21 PM   #164
Retired Pentaxian's Avatar
At the moment, the jp site says 1.11 is not available at this time, and there is nowhere to click to d/l v1.10, which is all I need to use my K-Adaptor properly. Anyone have a copy they can send me? Zip or just the .bin file.
pentaxian@mac.com
04-16-2013, 12:21 AM   #165
drougge's Avatar
QuoteOriginally posted by Retired Pentaxian Quote
You can still get it from Pentax. http://www.pentax.jp/english/support/digital/firmware/q_v110.zip
And if anyone wants 1.01 that's available as well. http://www.pentax.jp/english/support/digital/firmware/Q_E101M.zip
And of course 1.11 is actually still available too. http://www.pentax.jp/english/support/digital/firmware/q_v111.zip
camera, firmware, mirrorless, pentax, pentax q, pentax q firmware, pentax q10, pentax q7, q10, q7
Pentax K7 Firmware Updating to Version 1.11 Vadym Visitors' Center 2 02-07-2012 07:46 PM
K-r new firmware ver 1.11 murviper Pentax K-r 65 01-20-2012 09:49 PM
K-5 Firmware 1.11 on its way? kdre Pentax K-5 107 07-27-2011 10:53 PM
Problem Found with 1.11 Firmware on SilkyPix Infilllight Pentax Medium Format 2 07-25-2011 09:03 AM
Pentax K7 1.11 Firmware suggestions LaurenOE Pentax DSLR Discussion 26 06-21-2011 07:08 AM
All times are GMT -7. The time now is 02:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
