Show Printable Version 8 Likes Search this Thread
04-06-2013, 06:34 AM   #121
ebk
QuoteOriginally posted by robtcorl Quote
I have the zip download, but haven't used it yet.
Think I'll wait a bit to see if they re-offer it, bug free.
i installed the firmware.
made a video and pic's on the p and aut,
untill now nothing wrong.
04-06-2013, 07:58 AM   #122
QuoteOriginally posted by ebk Quote
Are you able to shot with the "Tone Expansion" filter and are your results what they should be? I'm still hesitant to install it...
04-06-2013, 02:38 PM   #123
hnikesch's Avatar
QuoteOriginally posted by Croneberg Quote
My tone Expansion filter is gone to monotone after the FW update, oh well I didn't use it anyway
Hans
04-07-2013, 04:56 AM   #124
steve1307's Avatar
Installed V1.11 on my Q which had a shutter count of 4.
I continued shooting on the same card and my file numbering kept going from there 5,6,7 .... etc
PhotoME doesnt seem to recognise the data and give the actual "shutter" count so i dont know if it was reset or not.
04-07-2013, 05:27 AM   #125
selar's Avatar
QuoteOriginally posted by steve1307 Quote
Photome can only read shutter count from RAW files.
04-07-2013, 06:13 AM   #126
hnikesch's Avatar
I see that FW 1.11 has been pulled from the US site without explanation, no notes it's just missing from the site.
QuoteOriginally posted by selar Quote
You can check the shutter count here. see link
https://www.pentaxforums.com/pages/check-shutter-count-exif.html
The 1.11 firmware is still available here
https://www.pentaxforums.com/news/pentax-q-firmware-111-released.html
Hans
04-07-2013, 08:57 AM - 1 Like   #127
Painter's Avatar
I'm not sure if it's been mentioned else where but Pentax Canada still has FW 1.11 on their site. I haven't come across any bugs myself and the focus is so improved they could have taken every other feature out tf the camera and I would still be happy
PENTAX RICOH IMAGING CANADA INC. | PENTAX Firmware Update Software for Q
04-07-2013, 09:10 AM   #128
steve1307's Avatar
oh yes of course, ok then....
file IMGP0001.dng is shutter count "2" with v1.10
I only took 4 test shots before going to v1.11 so I'd guess that the shutter count would be 4 less than the file number if it was reset.
file IMGP0104.dng, the last one says shutter count only 52. ??? odd.
Doesn't matter. Camera shuttercount is pretty irrelavent since it has no shutter in the body anyway.
It is nice and quick with v1.11, even indoors (at least with the 01 lens), I haven't tried the 02 yet.
04-07-2013, 02:09 PM   #129
QuoteOriginally posted by Painter Quote
Maybe a dumb question, but the Canadian download instructions are incomplete. The self-extracting file contains two .bin files: fwdc601p.bin and fwdc601p.bin.cpgz. Are both to be uploaded to the camera or, if only the first, what is the second? If both are used, does the sequence of loading matter? v 101 had only one such file for the camera, plus a second for a separate installation for the standard lens and another for the standard zoom.
04-07-2013, 02:57 PM   #130
hnikesch's Avatar
QuoteOriginally posted by penolta Quote
Only the fwdc601p.bin file is used
Check the properties of the file, if its created Tuesday, ‎March ‎12, ‎2013, ‏‎1:55:40 PM it's version 1.11 ~ if it's created Tuesday, ‎October ‎23, ‎2012, ‏‎4:34:39 AM it's version 1.10
Hans
04-07-2013, 04:12 PM   #131
v.1.11
Thanks, Hans. It is correct as is. I will just ignore the second file. Evidently the cpgz file is an archive file created today with the download.
04-07-2013, 08:34 PM   #132
le question
Incoming newbie question:
I just purchased a Pentax Q. Coming from simple point-and-shoot land, I'm learning a lot from the manual and from here. I didn't know the firmware was updatable until happening upon this forum. My camera still has firmware version 1.0. I've been reading about version 1.11 being pulled. So, my question is, is it safe/wise to just use the 1.01 and/or 1.10 firmware? Nothing *seems* wrong with the camera as-is, and I don't want to flash firmware that will cripple my camera.
I may try to update the camera and lens tonight.
I found a link and downloaded the 1.11 firmware since most people are saying nothing is wrong with it and it improves autofocus speed. I may just use it instead.
04-07-2013, 08:37 PM   #133
QuoteOriginally posted by yourbrokenoven Quote
Unless you shut down your camera while it's updating the firmware itself, you're not going to brick it. Generally speaking, the newer the firmware, the more stable your camera will be.
The v1.1 firmware for the Q is a particularly worthwhile update, as it adds focus peaking as well as support for the Q to K mount adapter and shake reduction with adapted lenses.
IDK why Pentax took down 1.11 (it probably has a trivial bug or something like that), but you can grab v1.10 using this link:
http://www.pentax.jp/english/support/digital/firmware/q_v110.zip
Installation instructions:
Pentax Q Firmware 1.11 Released - Pentax Camera News & Rumors - PentaxForums.com
04-07-2013, 08:42 PM   #134
VisualDarkness's Avatar
1.11 at least resets the shutter count (nothing to worry about) and breaks one filter (expanded tone or something) but I never use them anyway.
04-07-2013, 09:57 PM   #135
You really need to be shooting RAW to get the best out of the Q (and it's REALLY GOOD!) So filters and fancy effects are not even a concern, performance is. And with the 1.11 the camera performs extremely well....
camera, firmware, mirrorless, pentax, pentax q, pentax q firmware, pentax q10, pentax q7, q10, q7
Pentax K7 Firmware Updating to Version 1.11 Vadym Visitors' Center 2 02-07-2012 07:46 PM
K-r new firmware ver 1.11 murviper Pentax K-r 65 01-20-2012 09:49 PM
K-5 Firmware 1.11 on its way? kdre Pentax K-5 & K-5 II 107 07-27-2011 10:53 PM
Problem Found with 1.11 Firmware on SilkyPix Infilllight Pentax Medium Format 2 07-25-2011 09:03 AM
Pentax K7 1.11 Firmware suggestions LaurenOE Pentax DSLR Discussion 26 06-21-2011 07:08 AM
All times are GMT -7. The time now is 12:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
