03-28-2013, 01:16 AM   #1
Lowell Goudge's Avatar
Q adaptor aperture accuracy with non A lenses?
We all know the saga of aperture movement differences between K and KA lenses,
The question I have is somewhat related.
With the K to Q adaptor, has any one measured exactly the change in exposure when using a K mount lens, on the Q ?
I suspect that each "stop" as indicated on the scale of the adaptor is no longer a linear progression like it would be with a KA lens.
03-28-2013, 01:34 AM   #2
drougge's Avatar
It will vary per lens, just like it does if you try to A convert such lenses for use on a modern K mount body.
Unlike that case though there's nothing to be gained compared to using the aperture ring on the lens, is there? Maybe more exact control than half stops. You can usually set the (lens) aperture ring between clicks if you're careful though.
03-28-2013, 01:41 AM   #3
QuoteOriginally posted by drougge Quote
I think the only thing to be gained is perhaps using the adaptor like an open closed ring on a preset.
Since all true Pentax K lenses have half stop increments except for the first and last which are full stops, and also considering the non linear movement in the K mechanism, there is nothing else to be gained with the aperture ring on the adaptor.
I was just wondering if any one had measured the linearity of each lens to see if it is really lens to lens variable or somewhat consistent
03-28-2013, 02:44 AM   #4
drougge's Avatar
That will of course work.
You can always forget to move it to closed and be unable to close your lens down. Though that's probably not what most people consider a gain.
I tried to make A lenses from several older lenses a few years ago, it never worked properly, but it certainly varied in the specifics.
Of course others should try it too, it's not proper science without independant verification.
adaptor, aperture, camera, ka, lens, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Q with K adaptor... then attach 645 adaptor??!!! Unsinkable II Pentax Q 6 03-14-2013 07:41 PM
A german Pentax Q user with a weakness for manual lenses GoldMark Welcomes and Introductions 4 01-10-2013 09:50 AM
Can't use non-A lenses with K30 mortonbaychestnut Pentax K-30 & K-50 14 08-15-2012 02:27 PM
Displaying aperture with 'A' lenses Mychael Pentax K-5 9 11-19-2011 07:10 PM
M and A lenses exposure accuracy gregmoll Pentax SLR Lens Discussion 22 07-15-2009 04:46 AM
All times are GMT -7. The time now is 08:39 AM. | See also: NikonForums.com, part of our network of photo forums!
