03-29-2013, 01:45 PM   #1
Flinty's Avatar
Proper Fit Between the Adapter Q Mount and the Camera Q Mount
On my equipment there is an uncomfortable (to me) amount of rotational free play at this connection. The cavity on the adapter, into which the detent on the camera engages to lock the two in place, is a milled slot instead of the round hole one usually encounters. The slot is perpendicular to the circumferece of the mount, so that's not the problem. It just seems that the slot is a bit wide resulting in a sloppy fit between the two. Has anyone else encountered this configuraion? There seems to be a 1to2 degree amount of rotatation. A bit too much for me to give it a pass. I'm tempted to order another adapter for comparison. Any thoughts and observations from others will be most appreciated. Thank you.
03-29-2013, 01:47 PM   #2
QuoteOriginally posted by Flinty Quote
On my equipment there is an uncomfortable (to me) amount of rotational free play at this connection. The cavity on the adapter, into which the detent on the camera engages to lock the two in place, is a milled slot instead of the round hole one usually encounters. The slot is perpendicular to the circumferece of the mount, so that's not the problem. It just seems that the slot is a bit wide resulting in a sloppy fit between the two. Has anyone else encountered this configuraion? There seems to be a 1to2 degree amount of rotatation. A bit too much for me to give it a pass. I'm tempted to order another adapter for comparison. Any thoughts and observations from other will be most appreciated. Thank you.
All adapters will feel like this. It's a bit worse with third-party adapters, but because of the small size of the Q mount, even the genuine Pentax adapter has a little bit of play.
The issue is discussed in our review of the Pentax adapter:
Pentax K to Q-mount Adapter - Introduction - PentaxForums.com
03-29-2013, 01:56 PM   #3
Flinty's Avatar
Thank you Adam
Now I do remember that part of the review. I'll relax and let it be.
adapter, amount, bit, camera, mirrorless, mount, pentax q, pentax q10, pentax q7, q10, q7, slot
Looking for Pentax K PK mount to Q lense adapter SonDa5 Pentax K-01 3 12-20-2012 10:45 PM
Q w/ F-mount adapter [Photos] MarinatedHerring Pentax Q 4 12-11-2012 10:21 AM
Pentax Q to K mount adapter ? jogiba Pentax Camera and Field Accessories 23 12-08-2012 12:47 AM
The Q with D mount soo cool! i_trax Pentax Q 12 06-12-2012 02:08 PM
Pentax Q - K-mount adapter ! jogiba Pentax Q 98 09-13-2011 07:24 AM
All times are GMT -7. The time now is 11:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
