04-02-2013, 04:02 AM   #1
Lowell Goudge's Avatar
Q Adaptors general question
In looking at many of the Q adaptors, it is very hard to determine which, aside from the Pentax one, allow aperture control or open closed selection through the adaptor.
Are there any others or is Pentax alone on this?
Also, are there any M42 adaptors which would allow open closed switch on the adaptors?
04-02-2013, 05:46 AM   #2
hnikesch's Avatar
I have 2 Fotodiox adapters, my K mount adapter allows aperture control and works great on new lenses without aperture rings. I believe Fotodiox also sells one without aperture control not that you would want one. My Fotodiox 42mm adapter does not have aperture control. Don't most 42mm lenses have a on lens switch for for stop down DOF preview so you would not need a switch on a 42mm adapter. Below are links to the ones I have
Amazon.com: Fotodiox Lens Mount Adapter with Aperture Dial, Pentax K/PK Lens to Pentax Q-Series Camera, fits Pentax Q Mirrorless Cameras: Camera & Photo
Amazon.com: Fotodiox Lens Mount Adapter (Type 2), M42 (42mm x1 Thread Screw) Lens to Pentax Q-Series Camera, fits Pentax Q Mirrorless Cameras: Electronics
As I shoot mostly hand held I found that I really needed the Pentax adapter with built a in shutter to eliminate the jello effect of the electronic shutter that the Q uses for adapted lenses.
I use a K mount adapter for my 42mm lenses on my Pentax adapter and that combo works great. I now have 2 Forodiox adapters I will never use again.
Hans
04-02-2013, 06:28 AM   #3
thanks for the clarification.
I will likely go for the true pentax adaptor, just to take the jello out
04-03-2013, 06:21 PM   #4
LeRolls's Avatar
I've only had the official Pentax adapter for about a week but so far I like it. Just wish that it came with tripod foot. I received my DAL 55-300 from KEH today for some super zoom action and now I have to look into getting a good macro lens too.
04-03-2013, 07:49 PM   #5
hnikesch's Avatar
QuoteOriginally posted by LeRolls Quote
I got a tripod foot from ebay per one of Scott's posts that works well. See my pimped post and search for Scott's (snostrom) post on the tripod foot
Hans
https://www.pentaxforums.com/forums/pentax-q/208945-chinese-tripod-rings-pent...ml#post2209331
https://www.pentaxforums.com/forums/pentax-q/220584-show-me-your-pimped-q.html#post2337961
04-03-2013, 08:02 PM   #6
monochrome's Avatar
It is certainly pricey, but don't forget the official Pentax Tripod Foot. Mine makes the entire rig truly stable and useful. See the post in the Q Forum about how to order one from Pentax Parts (in USA or Canada).
04-04-2013, 03:17 AM   #7
Hans. The foot looks interesting, but I wonder about stability with anything but a hard mount. I had fits with my celestron C90 because it had the tripod foot mounted to the scope body through the rubber protective cladding (an option) . Ultimately I cut out the cladding over the foot mount, and set the mount to the body with epoxy to stop vibration that was causing loss of sharpness. That was on a K10. I would hate to see what any slightly soft or resilient mount would do to high frequency vibration with , say my K300/4 on a Q
04-04-2013, 05:44 AM   #8
hnikesch's Avatar
I altered the foot to fit tightly by grinding the stationary side to increase the gap so I could snug it on the barrel of the adapter. I get no movement or vibration when mounted to a stable tripod, it's hard plastic no rubber but doesn't damage the adapter.
Hans
PENTAX K-r  Photo
adaptors, camera, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7
General Stupid question Belcik Pentax DSLR Discussion 17 09-26-2012 09:27 AM
General Question lamented bovine Photographic Technique 14 09-03-2011 03:35 PM
A general Q about upgrading to * or ltd emr Pentax SLR Lens Discussion 26 02-19-2009 05:30 AM
General lense question? schmik Pentax SLR Lens Discussion 7 05-23-2008 01:06 PM
A general Question... meyjo Photographic Technique 15 01-31-2008 06:36 AM
All times are GMT -7. The time now is 04:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
