04-12-2013, 11:57 AM - 1 Like   #16
Lowell Goudge's Avatar
finally had a chance to show the issue with overactive shake reduction
both shots cropped down to the same size and area, taken only moments apart.
here is the Q with the K135/2.5 and focal length set to 135mm
here is the Q with the K135/2.5 and focal length set to 105mm
04-12-2013, 12:01 PM   #17
Wow. How did you arrive at the 105mm setting- trial and error? Is your result repeatable?
04-12-2013, 12:14 PM   #18
QuoteOriginally posted by cfraz Quote
it was a WAG. ( Wild A$$*& Guess) but what got me thinking was I could not remember if when I tried with my K300, whether when shooting I had upped the focal length from when I tried using my 70-210/3.5 series 1 lens. I kept thinking the K300 looked sharper than the zoom, so i simply went into the SR menu and dialed back from 135 to 105 (I was too lazy to go to the single digits column).
I have not tried to tune it better or tune other lenses as I have been travelling all week and had not had time to play but this is really something that needs to be explored.
I think I have noted it could be because I am using the tripod mount on the adapter as a handle, or in some cases a monopod support point, but the phyiscs is the same, using that point as a main support, it introduces a different location for the center of the pitch and yaw , than when simply holding the camera by the camera body as you would with a light weight lens of a Q lens
04-12-2013, 01:40 PM   #19
Thanks. Your suggestion that it might be due to supporting the camera by the lens mount seems a plausible explanation. Yet recommended practice is to support a long lens near its balance point when shooting a Pentax DSLR, I think, so wouldn't we observe the same behavior? An area worthy of more testing in any case. I'd like to hear of results if you pursue the issue.
04-12-2013, 01:53 PM   #20
part of my plan when testing the Q and writing the learning curve is to document observations as I go, and as I have 55 lenses in my collection i intend to try a goodly collection of them. I was disapointed by the results I have had with a couple of lenses, but now that I have seen some promising results, I am going to try this a little more systematically.
Note however, the purpose of me getting a Q is really a light weight birding solution, using one of my manual focus lenses (fine focus control plus focus peaking makes this a great combo) and will likely consider hand held/monopod mounted and not tripod mounted. I agree ideal mounting is to mount at the balance point, and I do that also with my 200-500/5.6 on the gimbal mount, and plan to test that lens also, but many tripod shooters may have SR off, and for flash SR is also off, and birders do like flash to nail the details, so we may not have enough real hard data yet.
watch this space because I will do more
04-12-2013, 03:37 PM   #21
robtcorl's Avatar
a little test
Lowell, I think you're onto something.
After seeing your photos, I had to do a little test myself.
I'm not good at analyzing IQ, but sure think I can tell a fair amount of difference.
Fotodiox adapter, Pentax M 135/3.5.
Handheld using a cheap loupe.
jpegs, straight OOC, no PP.
3 shot set of each at 135 and 105, best of each set chosen.
ISO: 250
Exposure: 1/200 sec
Aperture: f5.6
Focal Length: 135mm
same, but with 105mm setting, and 1/250 sec
A hairy woodpecker showed up.
I went to f3.5, and 400 ISO.
Probably would dress up a bit in PP. (for me, PP = Picasa processing)
I hope others will give this a try.
Maybe there's a sweet spot setting.
04-12-2013, 04:22 PM   #22
QuoteOriginally posted by robtcorl Quote
Wow... HUGE difference! I have that same 3.5 / M-135 & Fotodiox adapter. I've noticed the same soft results as in the first pic, but just thought it was the lens/camera combo. I'll have to try it with the SR at 105mm & see what kinda results I get.
04-12-2013, 05:16 PM   #23
ISO: 250
Exposure: 1/200 sec
Aperture: f5.6
Focal Length: 135mm
hey rob, just curious but you sure that is hairy woodpecker...it looks like a yellow bellied sapsucker but i live in va
lowell great work...i need to do some playing this weekend too...
04-12-2013, 05:35 PM   #24
dadipentak's Avatar
Great, Lowell--I'm on the curve myself so having an expert guide will be a great help.
04-12-2013, 05:39 PM   #25
robtcorl's Avatar
QuoteOriginally posted by pearsaab Quote
Dang you Amy, thought I'd nailed this one.
This peckerwood was feeding on dripping sap from our river birch.
at least I knew it was a woodpecker
04-12-2013, 05:41 PM   #26
I'll try it at 105 on the 135/3.5 m42 and try the 250 Vivitar lower as well. Thanks for the tip Lowell.
04-12-2013, 07:17 PM   #27
bob it's a much cooler woodpecker though
04-13-2013, 12:09 PM   #28
hnikesch's Avatar
I did some testing but the weather here is dark and cloudy so I had some exposure limitations. The tombstone were shot at about 1/60 sec, the dish @ 1/125 sec. All shot at ISO 125 First with my SMC-M 135 f3.5 @ f5.6 first I shot a base image on a tripod using a 12 sec. timer no SR, then shot several hand held shots with the only change being SR @ 135 & SR @ 105 on an image requiring me to focus. I then did the same on a scene requiring infinity focus. I then repeated the exercise with my Super-Takumar 150 f4 @ f5.6 with SR @ 150 & SR @ 135
I see a slight improvement with the lower SR when I had to focus the image on the tombstone, SR is really working 750mm & 825mm hand held @ 1/60. On the Dish images shot @ infinity I didn't see much difference.
Hans
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
04-13-2013, 06:21 PM   #29
robtcorl's Avatar
Another down and dirty test with the M 135/3.5.
Each is a best of a set of 3: focus, shoot, de-focus and re-focus, shoot, etc.
First shot with FL at 135mm, second at 100mm.
Handheld, f5.6, 200 ISO.
I'll try this with another lens or two soon.
04-14-2013, 04:54 AM   #30
To all those playing with the M135/3.5 and focal length , I thank you for your efforts, and I should try mine as well but remember the K135/2.5 is much longer physically, and much heavier both of which may lather the effect somewhat
batteries, camera, focus, foot, lcd, lenses, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, software
Learning Curve FA 43mm Lens Driline Pentax SLR Lens Discussion 36 03-26-2013 09:53 PM
K-5 in my stable, let the learning curve begin cmohr Pentax K-5 8 02-19-2012 07:00 PM
Let the learning curve commence!! BugsAunt Troubleshooting and Beginner Help 10 04-24-2011 09:36 AM
My new K2000: impressions and struggles up the learning curve shuttervox Pentax DSLR Discussion 10 07-12-2009 09:16 PM
What is the learning curve of the K20d? roverlr3 Pentax DSLR Discussion 17 09-13-2008 08:44 PM
All times are GMT -7. The time now is 03:16 AM. | See also: NikonForums.com, part of our network of photo forums!
