04-14-2013, 07:35 AM   #31
Lowell Goudge's Avatar
still a work in progress with the Q but using the K135/2.5 at F5.6 and the Q i am starting to get there
just a song sparrow and golden crowned kinglet
unfortunately the kinglet moved a little,
04-14-2013, 10:14 AM   #32
hnikesch's Avatar
I re-shot the tombstone test with some sun today, Shutter speeds on the 135mm shots were 1/800 sec. the 150mm were 1/640 sec. all shot at f5.6 ISO 125 so SR should not be working too hard. I shot the 135 with SR @ 135 and 105 and the 150 with SR @ 150 and 135. I shot 2 at each SR setting and chose the better. I found the results were better with the lower SR setting. see If you agree. The reference image shot with 02 @ 15mm (about 80mm) The base image shot on a tripod using the 12 sec. timer SR off, the rest hand held. No PP adjustments. other than resizing.
Hans
04-14-2013, 10:30 AM   #33
robtcorl's Avatar
I enlarged to try to get a better look.
To my old eyes, the base shot on the 135mm lens is best, with the 105 setting running a close second, both a fair amount better than the 135 setting.
On the 150mm lens I think the 135 setting is a bit better than the base or 150 setting.
04-14-2013, 10:47 AM   #34
Ok now khat we've had some fun with SR response, I am looking to the future of using the Q for birding. What is the best LCD hood there is with diopter adjustment. What is the best value for money. I need to be able to use this without taking my glasses off
04-14-2013, 11:31 AM   #35
hnikesch's Avatar
You use glasses for distance as do I. I have found that a I don't need the diopter adjustment and I really like the cheap hood for the Nikon 1 see link. The eye cup and built in lens work great with glasses. The lens is designed to allow someone with perfect vision or glasses focus on the LCD, I never take off my glasses to use it. Several here use it. The only issue is you must open up the hole for the tripod screw in the supplied mounting frame to allow the frame to move a little to the left to clear the buttons on the back of the Q.
Hans
V5 3" 4 3 LCD Viewfinder 2 8x Magnifier Extender Hood Eyecup for Nikon 1 J1 DSLR | eBay
04-14-2013, 11:52 AM   #36
robtcorl's Avatar
+2 on the V5.
Mine has enough play to miss the buttons, barely, but I plan to enlarge the hole one of these days.
04-14-2013, 02:26 PM   #37
Ok for $16 V5 is on order. We'll see how it works Can't be too bad for the price, hnikesch. Whatis your eyeglass adjustment, mine is 3.25 diopters in my right eye
04-14-2013, 02:38 PM   #38
crewl1's Avatar
QuoteOriginally posted by hnikesch Quote
Hans
Hans the 150 seems to show less CA than the 135 in these shots.
I don't do much hand held with the Q but will take heed to yours and Lowell's findings when I do.
04-14-2013, 02:42 PM   #39
crewl1's Avatar
If you decide to go with the V5 loupe and want to enlarge the hole, use a dremel with grinding tip rather than a drill.
The metal is a bit soft and will get torn up with a drill bit.
04-14-2013, 03:30 PM   #40
monochrome's Avatar
QuoteOriginally posted by crewl1 Quote
A small rat-tail file will also work - maybe better because you have more control.
04-14-2013, 04:07 PM   #41
I have both milling machine bits and small round stones for my drill press, as well Asa rat tail files and specific files for sharpening chain saws. Enlarging a small hole accurately is no issue.
Actually what will be more difficult, when it comes, is putting lens strap rings on the canon tripod mount I ordered
04-14-2013, 04:26 PM   #42
hnikesch's Avatar
Mine is 4.75 just call me blind
Hans
04-14-2013, 04:30 PM   #43
hnikesch's Avatar
I noticed the same, but it lacks a little more in contrast but that is easier to fix than the CA. It's a like new copy and seems fairly sharp
Hans
04-14-2013, 10:08 PM   #44
Hans
-12.5 right eye, -9.0 left eye. You get used to it
04-15-2013, 05:48 AM   #45
$5 Mamiya/Sekor 135mm/2.8 found in used junk at local B&M. Lens hood has embedded UV filter and is hefty,hefty,hefty. First attempt at 105mm this morning and more work on my focusing skills.Thanks for a great thread. Ironic that two of the employees of the Canikon empire there are enthralled with the possibilities of the Q. Now on to tripod mounts/supports.
batteries, camera, focus, foot, lcd, lenses, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, software
Learning Curve FA 43mm Lens Driline Pentax SLR Lens Discussion 36 03-26-2013 09:53 PM
K-5 in my stable, let the learning curve begin cmohr Pentax K-5 8 02-19-2012 07:00 PM
Let the learning curve commence!! BugsAunt Troubleshooting and Beginner Help 10 04-24-2011 09:36 AM
My new K2000: impressions and struggles up the learning curve shuttervox Pentax DSLR Discussion 10 07-12-2009 09:16 PM
What is the learning curve of the K20d? roverlr3 Pentax DSLR Discussion 17 09-13-2008 08:44 PM
All times are GMT -7. The time now is 02:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
