Originally posted by crewl1 Once you get the hood it will help. I find using the focus assist to magnify the screen helps me more than peaking when shooting distant targets like birds.
In this case the white peaking tends to distort the area I want to see in greater detail such as the bird's feathers, so I can actually focus more accurately using the magnification.
If you havent set it up yet go to the Focus menu ad turn on MF assist to x4. you activate it with the OK button.
Also, go to the wrench menu 2 and uncheck Power Saving so the display will not dim while you are focusing.
Agreed, the V5 hood is on order, just waiting for Santa to bring it.
I also agree the 4x focus assist would be much better for distant subjects than focus peaking because it cant really nail the subject focus, the DOF for the "good enough focus" is just to great. and distant only needs to be 30-40 feet. I have had shots that I consider acceptable, using focus peaking, it is just not consistent enough.
the hint on the power save feature is good, and now that I have 2 spare batteries, i will try it.
