Originally posted by Na Horuk Btw, the D800e, with its high MP count, is facing this problem because a lot of lenses that were perfectly decent on older models now no longer look as good on this camera. So if you make a sensor with much higher resolution, you also need to make lenses that match it.
This part isn't right. You don't need higher resolution lenses for the D800, you just have a use for them when you have them. The Q has less sensor area than anything else we compare it to, so you magnify more for the same viewing size. The D800 has the same sensor size as the D700 had, so for the same viewing size you don't magnify more, and therefore any lens that looked good on the D700 will look just as good on the D800. You just have to resist the urge to pixel peep.
