04-18-2013, 05:58 AM   #46
robtcorl's Avatar
Ah you kids, you gotta have the latest and greatest right now!
But this old timer sat back and waited until the kinks were worked out.
I held off on upgrading to 1.11, and then on 1.12 until the official release.
Add in the fact that I'm tech challenged, and afraid of bricking the little sucker.
My old 2,700+ shutter count camera is new again!
And oh my, what fast AF it now has!
04-18-2013, 06:02 AM   #47
hnikesch's Avatar
Ah yes, but 1, 1 and 2 are the first three numbers of the Fibonacci sequence....
True, true but the Fibonacci sequence starts "0" Going against the wind (I'm a Bob Seger fan) I am using 1.12 I see no degradation in AF from 1.11 if anything a slight improvement in dark area AF but that may just be a figment of my imagination.
Hans
04-18-2013, 06:23 AM   #48
Docrwm's Avatar
QuoteOriginally posted by hnikesch Quote
Hans
Hans,
Thanks for the report. I appreciate it.
04-18-2013, 09:23 AM   #49
Of course you know with a faster auto focus, it will wear out quicker, and Pentax will be selling more cameras/lenses
Lacro
04-18-2013, 11:26 AM   #50
hnikesch's Avatar
QuoteOriginally posted by lacro Quote
Lacro
No no no It will stay new for ever with 0 shutter actuation's, Oh wait, what shutter is that, the shutter in the 01 I sold or the one in the 02 I just got to replace it, or maybe it's the one in the PK 2 Q adapter, no it the one in the 06 I plan to get.
Hans
04-18-2013, 11:32 AM   #51
Docrwm's Avatar
Hans
No, it's the electronic shutter in the body
04-18-2013, 11:45 AM   #52
monochrome's Avatar
I assume since I have 1.11 saved in a folder on my hard drive, if I experiment with 1.12 on my second Q and if I don't like it as well I can reinstall 1.11 without any issues.
04-18-2013, 11:59 AM   #53
I don't think you can. THe firmware normally warns that if you upgrade you won't be able to restore to an older firmware. However, I've never tried to do it.
04-18-2013, 12:35 PM - 1 Like   #54
monochrome's Avatar
QuoteOriginally posted by DaveInPA Quote
Well then I guess I can still be the guinea pig if Q2 becomes my dedicated Qonverter body. I never much like the looks of White anyway
04-18-2013, 12:45 PM   #55
Mike.P's Avatar
Installed 1.12 over 1.11 ... AF is the same speed.
04-18-2013, 02:04 PM   #56
I've downgraded heaps of times from 1.10 to 1.01 and so on, and it always let me do it.
04-18-2013, 02:14 PM   #57
I updated mine this morning from and skipped 1.11 entirely. Now, every time I switch the camera on the date and time gets reset to New York and 2011. I tried it 4 times and it works OK until you switch the camera off. Also video setting resets from PAL to NTSC . I can't see what I'm doing wrong so I assume it must be the firmware.
04-18-2013, 02:17 PM   #58
QuoteOriginally posted by Phil A Quote
Wow, looks like a big bug O_o
04-18-2013, 03:13 PM   #59
robtcorl's Avatar
I skipped 1.11 too, but no problems at all with 1.12, no date etc resets after shutting down.
04-18-2013, 03:27 PM   #60
Sdyor's Avatar
Phil A " updated mine this morning from and skipped 1.11 entirely. Now, every time I switch the camera on the date and time gets reset to New York and 2011. I tried it 4 times and it works OK until you switch the camera off. Also video setting resets from PAL to NTSC . I can't see what I'm doing wrong so I assume it must be the firmware."
Make sure you you answer OK to 'Settings complete' before you hit menu after you enter settings. If not then get the behavior you are seeing.
camera, firmware, mirrorless, pentax, pentax q, pentax q firmware, pentax q10, pentax q7, q10, q7
Pentax Q Firmware 1.11 JPT Pentax Q 166 04-23-2013 08:38 AM
New Q firmware (1.11) thibs Pentax News and Rumors 36 04-03-2013 08:13 PM
Focus Peaking for the Q with Firmware 1.1 pico Pentax Q 113 12-20-2012 06:51 PM
New FIrmware Update v.1.12 geru2000 Pentax K-r 53 06-07-2012 11:30 AM
Firmware 1.12 coming? Mike.P Pentax K-5 21 01-11-2012 08:20 PM
All times are GMT -7. The time now is 09:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
