Originally posted by danou75 1/8000sec ISO250 f1.9 01 Prime lens, from a vehicle doing about 100km/h.
The sensor in the Q is quite slow. The set exposure time is
completely unrelated to how fast the sensor scans. (Slight simplification that is much more accurate than thinking about it like a shutter.)
Use 1/2000 or slower to avoid this problem (on that lens). Any lens with a shutter can avoid it, if you don't ask for a shorter exposure than the shutter can give you. Custom setting 13 "Electronic Shutter" can be set to disable and the camera will not let you set these jello settings any more. (Assuming the lens has a shutter.)
If you adapted lens is on an adapter without a shutter you will always have this problem with it. Use a tripod or get the adapter with the shutter.
