05-17-2013, 03:36 AM   #16
ChrisJ's Avatar
Chris,
Pretty good explanation, but there needs to be a correction.
TTL does read the light reflected off the sensor (or film) but does not use a preflash. It terminates the flash much like AUTO flash units, but the exposure continues until the end of the shutter period, leading potentially to over exposure in strong background light
P-TTL uses the cameras built in metering in the prism taking both ambient light and pre-flash light through the cameras normal metering, and then calculates the flash duration required in addition to the ambient to get the exposure.
TTL is a reactive process, P-TTL is a predictive process
Hi Lowell
That's why I said that TTL is good for fill in flash, often you want to use settings that remove the ambient and record just (or mostly) the flash component which is where Manual flash can score.
Chris
05-17-2013, 07:58 AM   #17
An auto flash should work cross brands, right? So long as the camera uses a standard hotshoe.
brands, camera, flash, flash for pentax, metz, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7, vivitar
Flash for the Q Lurch Pentax Q 24 04-09-2013 11:26 AM
Pentax Q, the little camera that could. lenshoarder Pentax Q 4 01-31-2013 07:37 PM
Little DIY For Pentax AF-540FGZ Flash daacon Pentax Camera and Field Accessories 4 01-16-2013 09:42 PM
One flash for Pentax Q and Samsung NX? Kirill_est Pentax Q 3 12-21-2011 02:03 AM
External flash for the Q devorama Pentax Q 19 11-17-2011 05:58 AM
All times are GMT -7. The time now is 02:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
