05-17-2013, 05:43 AM   #1
M.Zein's Avatar
Help, adapters stucked
I received today the fotodiox k to q adapter.
And was playing with my canon FD lens on it so here are the steps of my assembly:
here I have the q body aside,
I attached the FD lens to the fotodiox pro fd-pk adapter, then attached both to the fotodiox k-q and attached all the system to the q body.
It seems everything went well, I took few shots then tried to dismount the system.
Removed the k-q + fd-pk + lens from the q body OK
Try to remove k-q from FD-pk + Lens stuck
Remove the pk lens from fd-pk/k-q OK
Try to remove k-q from fd-pk. Stuck
On the q-k the ring is set to open, on the fd-pk the ring is set to install.
Help please
Am I missing a step?
Should I force it to open?
N.B:
The lever on the k-q is not moving either.
05-17-2013, 07:33 AM   #2
M.Zein's Avatar
Problem solved.
If anyone else faces this problem,
try to move the lever release hand to the base of the k-q adapter, it might seem stuck at first, this is because it is new, after few moves it will adjust on its own, then every mechanical piece will fit into its place and will operate smoothly after awhile.
05-17-2013, 08:32 AM   #3
crewl1's Avatar
Glad to hear you worked it out. I don't have that adapter so cant help. So lets see some sample shots with the Canon lens.
05-17-2013, 09:36 AM   #4
M.Zein's Avatar
Will try to post few shots tomorrow
05-17-2013, 10:06 AM   #5
boriscleto's Avatar
You would probably get better results with a FD to Q adapter...no corrective element.
05-17-2013, 10:49 AM   #6
M.Zein's Avatar
QuoteOriginally posted by boriscleto Quote
Will order one soon then if this is the case,
thanks for the advice.
adapter, body, camera, fd, fotodiox, lens, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, system
For Sale - Sold: Adaptall 2 PK/A adapters, Canon FD adapters NRV Shooter Sold Items 5 02-27-2013 01:55 PM
samyang 85mm stucked with LV random pentax user Pentax K-5 2 06-24-2011 09:53 AM
Polarizer Filter and Adapters Help krp Troubleshooting and Beginner Help 10 10-13-2010 05:42 AM
Using Non-INF adapters help arbib Pentax SLR Lens Discussion 8 10-22-2009 01:14 PM
Help with hot shoe adapters please! NYpHoToGraphEr Pentax Camera and Field Accessories 22 06-02-2009 12:10 PM
All times are GMT -7. The time now is 09:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
