Hi all,
I was sitting around waiting for hummingbirds with my K-5IIs, FA* 300/4.5 + F 1.7x AFA on a tripod, and had the Q + DA 55-300 with me for opportunistic handheld shots of whatever might show up in the surrounding area. I noticed a largish Jumping Spider appear on a fence post right in front of me, and backed off to the MFD of the lens (4.6ft or 1.4m) and grabbed a couple of shots since this was the closest thing to macro that I had with me. Earlier, I had grabbed a couple of shots of honey bees at the entrance to their indoor hive exhibit at the Nature Center.
These aren't great macro shots, by any means, but were relatively easy to shoot, even handheld since the critters weren't even aware that I was there. I probably should have used the pop up flash, since the angle wouldn't have been much of a problem at 4.5 ft, but didn't think of it at the time.
In the future, I plan to stick my Raynox DCR 250 in a pocket before heading off with the Q+DA55-300 to give me better macro capability, I'll also stop the lens down and use flash. . . live and learn. . .
Here are the shots:
These are much better than I had expected. NR and some significant sharpening applied in PP. Handheld with available light. Lens wide open at 300mm.
I'll include a couple of shots I got of a Red Bellied Woodpecker from about 35-40 feet, lens wide open and handheld at 300mm. These are pretty similar to what I can get with 500mm from about 12-15 feet with a K-5, and the RBWP didn't even know I was there, so they were easier to get from a subject intimidation standpoint. Also with this setup, from this kind of distance, DOF pretty much covers the entire bird while the DSLR setup would definitely have parts of the bird OOF. I probably should have backed off on the zoom a bit to get the entire bird in the frame, but I get a bit giddy having this much reach
Scott
