Originally posted by Digitalis Wouldn't it be HILARIOUS if pentax made a minature zoom mirror lens around 300-800mm f/5.6 It would probably be only somewhat larger than a 50mm f/2 lens..and they could include the same 40.5mm filters that they use for the DA* 560mm f/5.6 and D-FA 645 25mm f/4 - the filters could be used on the front of the lens.
It would be very cool, but I don't think that miniaturization like this would be possible since I believe that f stop for a cat lens is dependent on the diameter of the primary mirror and the FL of the lens, so it's not related to format at all. If you're talking about 300-800mm EQ, that's a different story because this would be a 53-143mm cat with the current 1/2.3" sensor, and would only need the primary mirror to be less than 30mm in diameter. They could actually probably make it even faster -- an f4 should be possible with the primary mirror at about 36mm.
Scott
