06-20-2013, 04:08 PM   #1
ND setting question
I need help...could not find in manual
How many stops loss of light results from setting the ND on
I have the Q with the 5-15 zoom
thanks in advance for any help
06-20-2013, 04:46 PM   #2
hnikesch's Avatar
The manual doesn't say but if you go to manual and set the exposure correctly then enable the ND filter it shows an under exposure of almost 2 stops or 1.6 stops
Hans
06-20-2013, 05:29 PM   #3
Hi mdodrill,
The idea behind the ND filter was to make up for the 1/2000 max shutter speed limitation when using the leaf shutters in the Q system Quality (AF) line lenses. This is relatively slow when you consider that the base ISO is 125. To match the 1/8000 max shutter speed of the electronic shutter, they added a 2 stop ND so the leaf shutters could be used under the same light intensity as when you use the electronic shutter. 1/2000 + 2 stop ND gives you equivalent exposure to 1/8000 at the same aperture and ISO.
Scott
camera, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Q's ND filter setting dh4412 Pentax Q 5 06-12-2013 06:17 AM
Q Shutter Setting Question ruggiex Pentax Q 6 01-24-2013 07:45 AM
MX ASA/ISO setting question Doan Pentax Film SLR Discussion 4 07-07-2012 11:53 AM
Macro setting LV focusing question emulsify Pentax K-r 13 01-28-2012 10:42 AM
ND Filter Question as relates to the DA 15 AlphaGAK20D Pentax SLR Lens Discussion 10 01-27-2012 07:29 AM
All times are GMT -7. The time now is 04:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
