06-27-2013, 12:44 PM   #1
Fisheye lens focuses past infinity
Is this normal? Mine focuses well past infinity, which is annoying because I just want to set it at infinity and go. Instead I have to actually focus, which takes a lot of time and is not 100% foolproof.
Charles.
06-27-2013, 12:46 PM   #2
carrrlangas's Avatar
I donīt know why, but it is normal.. Same thing happens to me with my fisheye.
06-27-2013, 12:46 PM   #3
QuoteOriginally posted by ChopperCharles Quote
Charles.
are you talking the q fisheye? if so mine does too and i think ithers have said the same
06-27-2013, 01:12 PM   #4
tclausen's Avatar
QuoteOriginally posted by pearsaab Quote
Yup, that's a fairly well known characteristics of the 03 fisheye for the Q. It's kinda annoying, but you learn to live with it eventually
06-27-2013, 03:48 PM   #5
Charles.
Many lenses are like this, as the amount it will go past infinity depends on the ambient temperature.
06-27-2013, 03:52 PM   #6
But this is true for 200mm and longer lenses, am I wrong?
06-27-2013, 04:34 PM   #7
It's unusual for a fisheye to need to focus past infinity. This is something that's normally seen on super tele lenses where focus needs to be very precise to allow for material expansion. My impression is that it's cheaper to manufacture like this, since no calibration is needed at the factory .. all the "toy" series lenses are like this, btw.
Assuming you don't shoot a lot of macros or close-ups frequently ..
the solution is simple - just tape it to the big mark left of center!
06-27-2013, 04:35 PM   #8
Anvh's Avatar
all autofocus can focus past infinitie as far as i know.
It has something to do with the autofocus and focussing on far away subjects.
06-27-2013, 09:31 PM   #9
So, on my 50mm manual K-mount lens, I could remove the grip and adjust the infinity stop. Is it possible to do that on the Q fisheye?
Charles.
06-27-2013, 10:38 PM   #10
crewl1's Avatar
Charles.
I haven't tried that.
For the time being I'm using tape.
I'd prefer to find a small rubber band instead.
06-28-2013, 02:35 AM   #11
Anvh's Avatar
Nope none of the AF lenses i know off have that option.
Introduction to Focusing
Most new autofocus camera lenses now allow focus past infinity so the autofocus mechanism does not suffer a jolt when seeking focus and racking to the infinity setting.
06-28-2013, 06:37 AM   #12
ve2vfd's Avatar
Don't forget that the Q fisheye is in the line of the "cheap toy lenses"... construction tolerances are not very tight, don't expect too much from it...
On the other hand for it's price it's an amazing tough little lens... mine survived a trip thru the washing machine in my trousers pockets... (darn tiny lenses!!!) it's a bit scratched and has mild water spots inside the lens and regardless of all that it's still usable.
Pat
06-28-2013, 08:28 AM   #13
Anvh... this is a manual focus lens
06-28-2013, 08:41 AM   #14
crewl1's Avatar
Following up on my note above - has anyone found a source for small bands that can be used on the 03 to keep the focus locked in one spot like these?
06-28-2013, 09:55 AM   #15
QuoteOriginally posted by ve2vfd Quote
Hi Pat,
I don't think this is necessarily the case. Though it's inexpensive and manual focus, It was never designated a "toy" lens, and doesn't perform like one, IMO. Instead of downgrading it to toy status, I think it should be appreciated for what it is -- the most affordable FE lens ever offered by an OEM for a system camera.
Perhaps it would make people happier if it was AF, didn't focus past infinity, and cost over $400 like most other OEM FEs.
That's amazing! I'd never expect that any lens would actually be usable after this.
IMO, Pentax released this lens as a bonus -- AFAIK, the only FE lens on a compact, to show that the Q system can go photographically where others will not.
Scott
camera, fisheye lens, infinity, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
DA15 goes past infinity Siegfried Pentax SLR Lens Discussion 19 11-13-2015 11:17 AM
Spotmatic focuses past infinity? kcobain1992 Pentax Film SLR Discussion 18 02-28-2011 08:26 AM
Lens focuses fine at close distance, not sure about infinity? bdery Pentax SLR Lens Discussion 4 08-16-2009 12:43 PM
300mm f4 m42 focuses past inf. on k10 Chris Stearns Pentax SLR Lens Discussion 4 05-27-2009 10:47 PM
Why focus past infinity alehel Pentax SLR Lens Discussion 8 05-15-2009 02:41 PM
All times are GMT -7. The time now is 07:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
