07-03-2013, 09:59 AM   #1
noviceinla's Avatar
Fireworks with Pentax Q
Hello, does anyone have any tips for this Q and MILC/dSLR newbie on capturing some nice shots of fireworks tomorrow night with the Q, using just the 01 standard prime lens? I don't have any new lenses yet.
07-03-2013, 12:07 PM - 1 Like   #2
geomez's Avatar
Tripod is a must. If you're not confident in Manual mode, shoot in Tv mode. Make sure you keep your ISO low to avoid noise. You'll also want 5+ second exposures if you want to burn in all the trails.
07-03-2013, 12:16 PM   #3
noviceinla's Avatar
Thank you, geomez. No other way around a tripod? I don't have one yet.
07-03-2013, 12:21 PM - 1 Like   #4
crewl1's Avatar
This a copy of my post in the fireworks info page.
I used a tripod.
First Independence Day show around my area this weekend.
Was able to set the Pentax Q with 03 Fisheye about 400 feet from the launch pads with interval shooting mode for unattended operation.
Each shot is result of a couple of frames stacked with Combine ZP.
2 sec (max on Q with the Toy lenses) ISO 125 (lowest on Q) f5.6 (fixed on the 03)
07-03-2013, 12:29 PM   #5
noviceinla's Avatar
Those are beautiful, Larry. I won't be able to pull any off that spectacular at this stage. I only have my 01 lens and no tripod. Whatever I capture is going to evolve into something extremely abstract after I edit. My future goal is the minimal editing the better, but I'm not to that point yet.
QuoteOriginally posted by crewl1 Quote
I used a tripod.
07-03-2013, 04:58 PM   #6
jimr-pdx's Avatar
If you can brace the camera against a post or some other solid item you can get a few steady images. A car doesn't really count as it's bouncier than most street signs or other items.
07-03-2013, 08:28 PM   #7
MegaPower's Avatar
Tripod is a must.
you can spend 5 bucks on a mini-tripod, still much better than putting it on any surface.
07-03-2013, 08:44 PM   #8
littledrawe's Avatar
Thrift stores, pawn shops, walmart...hit them all up to see if there is a cheap tripod out there. Make sure it has a quick release plate or the 1/4 lug to go into the bottom of the camera if it is second hand. if not a bag of rice would work, you could kind of karate chop a little cradle into the middle of it and work to point it up at the sky where the fireworks will explode. 2 second timer for pushing the shutter release. Voila.
camera, fireworks, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Q with 01 or Q with 02 kit? M.Zein Pentax Q 15 05-07-2013 05:18 PM
For Sale - Sold: Pentax q with extras!! Vcknot Sold Items 3 05-02-2013 06:06 AM
pentax q video with 06 lens, pk adapter with da200mm and da300mm pearsaab Pentax Q 10 03-07-2013 11:18 AM
Fotodiox Q to K with Pentax DA 40mm f/2.8 Lens on Pentax Q SonDa5 Pentax Q 3 12-26-2012 06:29 PM
Pentax Q with DA300mm mpreston Pentax Q 17 05-26-2012 12:31 PM
All times are GMT -7. The time now is 06:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
