I have been following the Q/10/7 forum for some time now and it seems to me that there are two problems with the camera that members may be kind enough to clarify for me before purchasing, I'm looking at the original Q.
I have a K200D with a fairly large assortment of manual lenses all of which I'm finding a bit too much to carry around (I'm in my 70's), I tried reducing the weight by using an 18-125mm lens but still found it was a bit too big and heavy and not at all discreet. I also have a Ricoh CX1 28-200mm lens all up weight 180g even though this has a very good 920,000 dot screen it clearly demonstrates to me the difficulties of seeing what you are doing in bright sunlight, we do occasionally get some.
The Q would be used with it's own lenses primarily for landscape and buildings but come winter a lot of wild coastal birds return from their summer holidays and I really need something to get near them, the sea shore around here is largely mud flats when the tide is out and in or out there is very little cover where you can creep up, they have excellent sentries even though they are protected species here. I was thinking of using the Q with my M 150mm or M 200mm attached for their reach.
I have noted the lengths some members go to to see the screen, I can see where an optical viewfinder will cover the view for the standard zoom or prime view but this still leaves you trying to see the on screen data, focusing etc. If you have to carry all this supplementary gear to be able to use long lenses it seems to me to negate the whole advantage of a small lightweight camera.
So is there really that much trouble with the viewfinder ?
Kind Regards
CD
