The new Fotodiox Pentax K - Q adapter has been redesigned so I ordered one to see what is different about it. I paid 26.00 plus tax from Amazon.
Amazon.com: Fotodiox Lens Mount Adapter with Aperture Dial, Pentax K/PK Lens to Pentax Q-Series Camera, fits Pentax Q Mirrorless Cameras: Camera & Photo
Right off the bat the design looks more modern, sporting a stacked cylinder look vs the older one's funnel design.
This version does not have a tripod mount or any obvious mounting area, so if needed you will have to find a lens solution.
The Q mount would be stressed too much by the weight leverage of a lens on the end of this mount (except for maybe the DA40XS.)
This version appears to only be sold with an aperture ring which is great, since on the old one there were two versions so you had to take care not order the wrong one (non aperture was cheapest cost.)
For DA lens use you need to have an aperture control on the adapter since the Q cannot control aperture of adapted lenses.
The aperture ring on this new design is a stepless design, vs the old one's click stop design.
It does not have a scale or any marks to tell you where you have set it.
The ring has an extremely short throw from stop to stop, as the movement of the ring translates directly to the aperture arm.
I put a piece of tape on one of the ring notches to show the extent of movement.
On an FA50 1.4 the ring takes the lens from wide open to approx F8.
The ring moves smoothly but i noticed some bits of grease oozing a bit from the edges of the ring, so it would be a good a idea to work the aperture a bit to get most of this out before handling it around camera/lenses or have a rag to wipe it off.
In use the new build quality seems more refined than the old one. The adapter easily mounted and clicked in place on the lens and the Q. The Q end has a tiny bit of play, but so does the Pentax OEM unit.
The short throw and absence of markings do make the aperture control less friendly than it should. I mounted a DA*300 and in contrast to the OEM adapter where I know what setting is best and can quickly dial it in, with this new fotodiox I have no idea where I am setting it and if I get a good position I will not be able to duplicate it unless I paint my own markings on the unit.
I had fading light for these samples, next chance I get I will take it out for some shots in better light.
If not for the short throw and lack of markings this unit would be perfect.
For $26 I think it is worth it for someone wanting to try out adapting their K lenses on the Q and not wanting to spend yet 10x as much on the OEM adapter.
Stick a label on the barrel with some ruler marks and paint a dot on the aperture ring and you should be all set.
