Originally posted by Neopifex Ah, okay. I thought that would be the case. Thanks for the answer!
Actually,it is possible to use small format lenses in something like the way you ask. You need to use a second lens, such as a 35mm macro lens as a relay lens. I have done this with a Cosmicar 8.5mm cctv lens in C mount. It works fine and gives you the kind of pictures you probably wouldn't get any other way. I found this technique on line and spent many happy hours replicating it with items from my photo -junk box. Try googling "roll your own lens" for the original article that I followed.
