08-28-2013, 05:17 AM   #1
Settings when using fotodiox adapter and 75-150mm lens
I have recently bought a fotodiox adapter for my Q as well as an old SMC PENTAX-M ZOOM 1:4 75-150mm.
When I switch on the camera, it ask me to enter the focal lenght, should I enter 150, 75, in between?
Thanks
08-28-2013, 06:03 AM   #2
hnikesch's Avatar
I enter the zoom FL I plan to shoot or a little less. If I am using my 80-200 zoom I enter 150 unless I plan to shoot only @200. Using adapted lenses on the Q is not a fast or quick process you will have plenty to time to change the lens focal length input between shots to the zoom range you are shooting. The fastest way is to power down and up and change lens FL.
Hans
08-28-2013, 06:15 AM   #3
Not ideal for moving object then. Thanks Hans.
08-28-2013, 07:07 AM - 1 Like   #4
hnikesch's Avatar
The input for FL only effects shake reduction and if you are following motion you should turn SR off so at that point the FL input does not effect the image so set it to the mid point and the camera will ignore it
Hans
adapter, camera, fotodiox, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Fotodiox Pentax 67 Lens to P645 Camera adapter LaHo Pentax Medium Format 18 01-02-2016 11:58 AM
fotodiox adapter backdrop001 Pentax Q 11 06-12-2013 06:17 AM
Fotodiox adapter question GibbyTheMole Pentax Q 60 02-10-2013 08:07 PM
For Sale - Sold: Pentax-M 75-150mm f/4 Lens s4int Sold Items 7 08-01-2012 10:14 AM
For Sale - Sold: M 75-150mm lens and PK extension tube set kibipod Sold Items 9 06-23-2009 10:08 AM
All times are GMT -7. The time now is 11:10 AM. | See also: NikonForums.com, part of our network of photo forums!
