09-18-2013, 07:09 AM   #1
Pentax Q7 vs MX-1 = same CMos ?!?!
Hi All !...
Pentax Q7 seems very interesting for Astro-Photography...
= it's a rare Good Small-Sensor DSLR with Interchangeable Lens System :
Members - Astronomy photos
would be nice to use for Travel Photography too ?
in that use case, Q7 OOC Image Quality somewhat worries me :
- heavy JPEG Compression isn't on par with MX-1's Image Quality !
- JPEG size from MX-1 is 50% bigger than Q7 JPEG size
- high iso IQ seems very inferior versus MX-1
were DPR and I-R Tests performed from a "still in developpement" Q7 ?
is PentaxForums planning a : Q7 vs MX-1 JPEG & RAW IQ Test ?
the iso 100 DPR Test discards any Lens Problem :
though the Size of the Q7 JPEG is very little due to Heavy Compression...
... Image Quality from both Cameras seems equally good ?
crops from DPR and I-R samples :
- DPR = Q7 left --- MX-1 right
- I-R = MX-1 left / Q7 right
size = 6MB vs 3.5 MB
09-18-2013, 09:33 AM   #2
Aegon's Avatar
MX-1 images look better to me.
09-18-2013, 10:45 AM   #3
The MX-1 has a better lens, that why its pics look better.
09-18-2013, 11:16 AM   #4
Pentax Q7 vs MX-1 = same CMos / same DSP ?!?!
thanx for your reply !...
I knew the 02 Standard Zoom was somewhat a Toy-Lens before posting...
... that's why I cropped the Center from the DPR samples !
and you can Verify by yourself = the Q7 iso 100 crop is Fine !
. ( despite the Q7 higher JPEG Compression Ratio ! )
vs the Q7 iso 3200 crop is way too smoothed
that's why I asked for a Q7 vs MX-1 JPEG & RAW IQ Test
many thanks if you could post such a Comparative Test :
- Q7 with its 01 Standard Prime
- vs the MX-1
thanx again !...
09-18-2013, 11:21 AM   #5
QuoteOriginally posted by geo444 Quote
many thanks if you could post such a Comparative Test : - Q7 with its 01 Standard Prime - vs the MX-1
We aren't planning to do one for our homepage, but perhaps a user with both cameras could!
IMO the bottom line is if you care about image quality more than about small size, don't get a Q or a Q7.
09-18-2013, 12:38 PM   #6
6BQ5's Avatar
But is the IQ here strictly related to the lens? Could a good lens on the Q7 match or maybe even exceed the MX-1? Assume RAW/DNG shooting only.
I've look at scaled-down telephoto pictures taken with a Q7 and the K-Q adapter and the results look pretty good.
09-18-2013, 01:02 PM   #7
I can't see big differences / RAW !
it is only a JPEG-Engine ( DSP ) Problem :
-- at all iso settings : Q7 JPEGs are Way too Compressed...
+ at high iso setting : Q7 JPEGs are Way too Smoothed !
take a look at file-sizes :
another crop / DPR
- Q7 left --- MX-1 right
- RAWs up / JPEGs down
+ take a look at the file-sizes :
MX-1 Raw is 7% bigger vs Jpeg is 47% !
09-18-2013, 03:04 PM   #8
6BQ5's Avatar
I thought the RAW DNG sensor data, if uncompressed, always is the same quantity (i.e. the number of pixels is always constant). These files have an embedded JPG, right? Does the difference in the RAW DNG file come from differences in the embedded JPG which may see more or less compression?
09-18-2013, 03:33 PM   #9
DNG files are losslessly compressed (using huffman coding or a similar scheme), so their filesize still varies based on the frequency of different color values. Because the precision of color values in raw files is substantially higher than in JPEGs, individual colors don't repeat themselves as often, so variations in filesize tend to be small.
09-18-2013, 03:48 PM   #10
Pentax Q7 vs MX-1 = same CMos / different DSP
QuoteOriginally posted by 6BQ5 Quote
I thought the RAW DNG sensor data, if uncompressed, always is the same quantity (i.e. the number of pixels is always constant)...
Right, but here are ziped RAWs ( 12 MPix x 1.5 (12 bit) x 3 (colors) = 54 MB
mean compress ratio for such files is ~2.5... 54 / 2.5 = 21.6 )
thus the file-size is Noise and Detail sensitive
... These files have an embedded JPG, right? Does the difference in the RAW DNG file come from differences in the embedded JPG which may see more or less compression?
yes the embedded JPEG could make the tiny difference...
but here IMO, the RAW files from both Cameras are very similar !
vs the OOC JPEG from the MX-1 are way better than those from the Q7 !
especially when pushing the iso setting !
let's hope some FirmWare update for the Q7 ?
09-18-2013, 04:35 PM   #11
drougge's Avatar
The DNG format certainly allows for compression, but the sensor data in the DNG files from the Q7 are not compressed. I just downloaded one from DPR to verify that. The only significant size difference comes from the embedded JPEGs.
No that's completely wrong, there are 12M photosites total, no x3. (Only one colour per photosite.) Total 18MB of sensor data. The file size is sensitive to image content, but only because the JPEG part changes size.
09-18-2013, 04:48 PM   #12
QuoteOriginally posted by drougge Quote
100% right drougge and 6BQ5 !!!
I was inside the Memory of my Computer... after demosaicing !!
Not inside the Sensor... before demosaicing !
here it's too late now !
09-18-2013, 06:57 PM   #13
6BQ5's Avatar
I completely forgot about this and only remembered as I was thinking of this thread on my way back home from work.
ePhotoZine published a review of the Q7 and they posted DNG sample files. I even commented on the review thanking them for the samples. Here is the link.
Pentax Q7 Review
When I loaded the DNG files into Aperture I remember thinking that the quality was decent. Now after some thought I wonder how much sharper the images could be with a better lens. I wish I could see some DNG samples from a Q7 with a K lens in telephoto mode!
09-18-2013, 07:19 PM   #14
Aren't the DNG files uncompressed on the Q (at least on the original crop-sensor model)?
Mine always come out above 20 MB, bigger than many of the compressed files on the K5 and K-01.
09-18-2013, 07:48 PM   #15
QuoteOriginally posted by lytrytyr Quote
Yup, I guess the Q cameras don't compress their DNGs to speed up shooting speed (which is a good thing). All I'm saying is that raw files, like jpegs, can be compressed, just not in a lossy manner.
camera, dpr, image, jpeg, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, quality, size, test, vs
Q vs. MX-1 - Same sensor? 6BQ5 Pentax Mirrorless Cameras 5 08-07-2013 03:57 PM
Canon G15 vs. Pentax MX-1 Amoon Pentax Compact Cameras 4 04-03-2013 06:26 PM
PENTAX MX-1 HIGH-END DIGITAL COMPACT WINS PRESTIGIOUS 2013 DESIGN AWARD MX-1 Receives Adam Homepage & Official Pentax News 6 03-21-2013 09:58 PM
DXO Tests MX-1, Same Results as Q PenTX Pentax Q 4 03-02-2013 05:44 AM
K-01 use the same CMOS of X-PRO 1? yipchunyu Pentax K-01 5 02-24-2012 03:53 PM
All times are GMT -7. The time now is 10:14 AM. | See also: NikonForums.com, part of our network of photo forums!
