09-24-2013, 12:17 PM   #16
QuoteOriginally posted by crewl1 Quote
Good ideas. I will try higher ISO values next also.
I did run a comparison with the DA*300 at base ISO's -results were pretty similar.
Thanks for posting these, you are making it harder for me to resist the call of the Q7. If you want to compare the Q and Q7 using the DA*200, let me know. I'm looking at these right now on an older monitor at work that's not as good as my monitor at home, but on these I can see a fair amount of difference between the two using the Bigma, less using the DA*300. It seems like there's less CA with the Q7 - I've noticed the same adapted lenses on the Q have more than I was used to seeing on other cameras.
09-25-2013, 07:57 AM   #17
crewl1's Avatar
Yes these tiny sensors are tough on lenses, every fault is magnified.
I will take you up on your DA*200 offer for our next meetup.
Hmmm maybe it is time to start planning.
bigma, camera, diffraction, hope, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, shot, shots, time
Post Q7 shots in Q/Q10 adapted lens thread? barondla Pentax Q 2 09-19-2013 04:51 PM
Adapted Lenses - is faster better? stormtech Pentax Q 38 12-22-2012 06:02 AM
With HDMI out & 3.5mm stereo mic in the K-01 is better than the K-30 for video jogiba Pentax K-01 2 05-22-2012 01:52 PM
Fuji X10 Review - better than Q? Adam Non-Pentax Cameras: Canon, Nikon, etc. 23 12-18-2011 06:04 PM
DA35/2.4 is better than FA35/2 in serious tests ogl Pentax SLR Lens Discussion 20 03-03-2011 02:02 PM
All times are GMT -7. The time now is 01:17 PM. | See also: NikonForums.com, part of our network of photo forums!
