10-22-2013, 01:10 PM - 1 Like   #1
VisualDarkness's Avatar
Pentax Q DIY Pinhole lens
In short, I tried to make a Skinkpinhole lens for the Q at a much lower cost.
Aesthetically it has that slim look that just suits the Q well.
I heard rumors that the machining work is a bit subpar with loose tolerances and I actually think that Visualdarkness Inc once again went with paper in the construction, the good news is that it's a sturdier paper and it's actually taped this time.
I think it's pretty much on par with the Skinkpinhole shots that are out there, except for the wonky OOF highlights, but that's not saying much and I doubt that you can see a MTF with the lens. My very unscientific (it's way too hard to see a target) focal length testing tells me that it's between 9-11mm, probably at the lower end.
This pillow was the best target for FL testing due to large colorful areas so that I could measure by something.
This one makes me dizzy.
Yes, it's actually a lamp.
A flower or a hugging seamonster?
Can you guess the lenses?
10-22-2013, 01:35 PM   #2
crewl1's Avatar
QuoteOriginally posted by VisualDarkness Quote
LOL BTW the OOF highlights in this one are quite interesting.
Sigma 50-500 and DA*300?
Better add this one to the adapted lenses thread - other mount (Q) before someone beats you to it.
10-22-2013, 02:06 PM   #3
QuoteOriginally posted by crewl1 Quote
At first I got a double image due to a bad hole so I consider the OOF points a huge improvement.
Much smaller.
Wait 'til I post my second DIY lens for today! It's a way more interesting one, although less sturdy and won't go in you pocket together with the camera.
10-22-2013, 07:44 PM   #4
Neat idea. Haven't done a pinhole on the Q. Need to try this myself. Will probably use tin foil.
thanks
barondla
camera, diy, diy pinhole, flickr, lens, mirrorless, pentax, pentax q, pentax q10, pentax q7, pinhole, q10, q7, test
For Sale - Sold: Pinhole Lens tas 0425 Sold Items 7 07-16-2013 01:18 PM
Fotodiox Q to K with Pentax DA 40mm f/2.8 Lens on Pentax Q SonDa5 Pentax Q 3 12-26-2012 06:29 PM
Q 12mm Pancake lens DIY Painter Pentax Q 8 11-19-2012 02:00 PM
DIY tilt/shift lens for Pentax K? alspe Pentax SLR Lens Discussion 9 09-18-2012 02:57 AM
Pinhole Lens and some sunsets JahJahwarrior Post Your Photos! 2 10-13-2007 08:57 PM
All times are GMT -7. The time now is 11:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
