01-12-2014, 12:59 PM   #16
Hi gennelman,
Welcome to the Q forum!!!
If your main purpose is to shoot food, I think that you may not need true macro capabilities, just close minimum focusing distance with a more standard lens. A 1:1 macro with the Q gives you a life sized image (about 6mm fills the frame horizontally). A standard dedicated macro would be more appropriate if you wanted to fill the frame with a single baby pea.
If, for example, you are shooting a relatively normal plate (@ 9") of food, then the 01 normal lens (8.5mm) will do this easily, as would most of the focal lengths within the 02 zoom (5-15mm). This would not need any adapter, give you the advantage of AF, the mechanical shutter, very fast flash sync, save you money, and make your Q kit for this much more compact.
Scott
01-12-2014, 05:05 PM   #17
QuoteOriginally posted by snostorm Quote
Hi gennelman,
Scott
Hey Snostorm!
Thank you for the welcome. =)
Surprisingly, I think i understood what you are telling me. I actually have been using the prime lens for a while for that purpose, together with the macro/ food shot option of the Q.
I did consider getting the telephoto lens for the Q. But do you think it'll help? It costs around 6,000 Philippine Pesos here. Roughly $140. So i was thinking I might be better off getting an extension tube or an adapter. (Btw the K-q mount here goes for around $200.)
But I guess, I'm looking to upgrade things a little bit more with better macro capabilities. Eventually, of course, I'd like to go all the way to full blown macro lenses. But for now, I just want to slowly inch my way towards it. (Also giving me enough time to get a really good feel of it and save up for the big deal.)
What do you think? =/
Salamat!
aperature, camera, lens, lenses, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7, verses, version
Pentax Q-to-K Adapter Docrwm Pentax Mirrorless Cameras 33 05-15-2013 09:40 PM
Genuine Pentax K to Q adapter excanonfd Pentax Q 31 04-08-2013 07:54 AM
Pentax K to Q adapter review Adam Pentax Q 31 04-07-2013 05:49 AM
Pentax Q / adapter K to Q / DA 35mm f2.4 AL wax Pentax Q 4 11-06-2012 02:55 AM
Pentax K-AC10U power adapter. Any cheaper options? PentaxKangaroo Pentax Camera and Field Accessories 13 04-05-2008 02:32 AM
All times are GMT -7. The time now is 10:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
