12-05-2013, 06:07 AM   #1
i_trax's Avatar
new firmware for Q and Q10 and Q7
Latest PENTAX Q Firmware Update : Software Downloads | RICOH IMAGING
12-05-2013, 08:04 AM   #2
Beyond the 08 lens recognition,
are there any surprises hidden in the usual
"Improved stability for general performance"?
I'd love to be able to switch the ND filter
on and off through the front wheel on the original Q.
12-05-2013, 08:35 AM   #3
QuoteOriginally posted by lytrytyr Quote
You'd need to pay for that firmware improvement.
Its called Q7
But even on the Q7, its a bit lame atm.
The quick dial has 4 positions.
If its set to ND on/off as an option, it will only have ND On or ND Off for the 4 positions.
No mix and match to other options or filters.
12-05-2013, 10:22 AM   #4
blackcloudbrew's Avatar
I'm not seeing any firmware update for the Q7. Are we still on version 1.0 for the Q7?
12-05-2013, 11:42 AM - 1 Like   #5
crewl1's Avatar
QuoteOriginally posted by blackcloudbrew Quote
Latest PENTAX Q7 Firmware Update : Software Downloads | RICOH IMAGING
Thank you for using a PENTAX Q7 digital camera.
RICOH IMAGING COMPANY, LTD. wishes to announce the release of Firmware Update Software Version 1.01 for PENTAX Q7.
Firmware in this document is the software that runs inside digital cameras.
Changes to V1.01
  • Correspond to [PENTAX-08 WIDE ZOOM].
  • Attached lens firmware version can be displayed on [Firmware Info] in the [Set-up 4] menu.
  • Improved performance of green button setting on M mode.
  • Improved stability for general performance.
Caution
  • Only PENTAX Q7 users are permitted to download the firmware update.
12-05-2013, 12:18 PM   #6
Well, how about that! Thanks!
12-05-2013, 03:47 PM   #7
wolfiegirl's Avatar
Thanks for the heads up! Have now updated.
But a different question re firmware. Hope it's ok to ask here. I updated the 02 lens firmware a few days back and then tried to do the same for the 01 prime one, but the camera won't let me? Will the 02 lens firmware cover both the 01 and 02? *confused*
12-05-2013, 03:48 PM   #8
crewl1's Avatar
01 lens must be installed to update the firmware. Make sure it isn't already up to date, though. The firmware menu screen will show you what version for each lens you have attached.
Each lens has its own firmware update file.
12-05-2013, 03:56 PM   #9
wolfiegirl's Avatar
QuoteOriginally posted by crewl1 Quote
oh tricky. ok
there is no 01 firmware listed. so will try and do that now.
12-05-2013, 04:01 PM   #10
crewl1's Avatar
QuoteOriginally posted by wolfiegirl Quote
oh tricky. ok
Really? When I install the 01 lens on the camera then go to the firmware menu it shows the Lens 01 firmware.
It only shows the firmware for the lens you have attached on the camera at that time.
12-05-2013, 04:08 PM   #11
wolfiegirl's Avatar
Ah that explains it then. Have just updated it.
Meanwhile, after the 1.14 update, every time I switch it on, it goes straight to settings to change language and time. ARGGGH! anyone else getting the same thing?
12-05-2013, 04:12 PM   #12
crewl1's Avatar
I haven't done the 1.14 update yet but pretty much all the firmware updates for the Q reset your camera settings.
Make sure you are actually doing all the OK's at the date time area or it will not take.
I think there is one extra one at the bottom that everyone misses.
12-05-2013, 04:25 PM   #13
Hi Wolfiegirl
I guess you did not read the explanation about the update?
After every F/W update the Camera is reset to default,which means all the settings need to be
reset.
Best Regards
Ted Hinsch
12-05-2013, 04:30 PM   #14
wolfiegirl's Avatar
I must have missed a button. Because I've switched it on and off with three different sd cards (no more updates) and every time they ask me to set date etc.
12-05-2013, 04:39 PM   #15
crewl1's Avatar
See this post https://www.pentaxforums.com/forums/136-pentax-q/221933-pentax-q-firmware-1-1...ml#post2356750
camera, firmware, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Small Flashes for the Q/Q10/Q7 Docrwm Pentax Q 29 11-29-2014 09:10 AM
New firmware for Q & Q10 July 4, 2013 Docrwm Pentax Q 27 12-07-2013 07:49 AM
Do the Q10 and Q7 have a Magnesium Body like the Original Q? seventhdr Pentax Q 3 08-06-2013 12:13 AM
Difference betw Q and Q10 after firmware updates Lampo Pentax Q 8 07-22-2013 12:23 AM
Q lens equivalents for Q/Q10 vs Q7 Docrwm Pentax Q 41 06-27-2013 03:05 PM
All times are GMT -7. The time now is 04:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
