12-16-2013, 06:17 PM   #1
Q won't turn on after firmware 1.13
Just got a second hand Q in great shape. Had the original firmware and it seemed to be working fine.
I followed the instructions completely to update the firmware to 1.13, saw the 'complete' message at the end and now the camera will not turn on.
If I take the battery out and put it back in, when I push the power on it sounds like the lens makes some sound but then nothing happens.
Anyone have a clue? Is my camera bricked? Will Pentax do anything for me even though it is outside the 1 year warranty?
Thanks
12-16-2013, 06:38 PM   #2
Does anything happen when no lens is mounted? I'm not sure if Pentax warrants firmware updates gone wrong, but it might be worth a shot.
12-16-2013, 06:48 PM   #3
No the camera doesn't do anything without a lens mounted.
I sent an email to Pentax yesterday. Hopefully they will have something I can try.
12-16-2013, 06:57 PM   #4
p38arover's Avatar
I had exactly the same problem with my upgrade of my Q to V1.12 - that's why I haven't upgraded since.
See https://www.pentaxforums.com/forums/136-pentax-q/221933-pentax-q-firmware-1-1...ml#post2358564
The camera had to go back to Japan for repair.
Ron
12-16-2013, 07:02 PM   #5
Thanks Ron. Do you mind giving me a heads up on how much that cost?
Andrew
12-16-2013, 07:03 PM   #6
Hmmmm...I'm reminded that I haven't done latest update. Maybe I don't want to...
12-16-2013, 07:08 PM   #7
Bummer. Try without a lens, as Adams said. If that doesn't work try leaving the battery out for four to five days and see if it will reset. If none of this works it will have to go in for repair.
Friend had this problem with his K-7. It did half the FW update, and got stuck. Instructions said not to turn camera off. Battery died- basically turning camera off, hours later. Pentax US fixed his camera (it was in warranty). You have a used camera so they may not fix it for free.
good luck
barondla
12-16-2013, 07:18 PM   #8
QuoteOriginally posted by barondla Quote
good luck
barondla
On the other hand, maybe I better do it while I'm still under warranty...
12-16-2013, 07:22 PM   #9
Will leaving the battery out for a few days really reset it?
Yeah take advantage of the warranty if you've got it!
12-16-2013, 08:54 PM   #10
Emperor and Senpai
VoiceOfReason's Avatar
Try holding down on the power button for 30 seconds while the battery is out, then fully charge the battery, and then try it again.
12-16-2013, 09:24 PM   #11
QuoteOriginally posted by VoiceOfReason Quote
No luck.
12-16-2013, 09:25 PM   #12
QuoteOriginally posted by p38arover Quote
Ron
Andrew
12-16-2013, 11:24 PM   #13
From experience flashing phones, it sounds like a corrupted firmware file. What happened immediately after the complete message?
12-17-2013, 04:24 AM   #14
p38arover's Avatar
QuoteOriginally posted by ajhill287 Quote
Andrew
As I noted in that thread, it was done free of charge. Pentax Australia have been very good.
https://www.pentaxforums.com/forums/136-pentax-q/221933-pentax-q-firmware-1-1...ml#post2453192
12-17-2013, 05:05 AM   #15
QuoteOriginally posted by dansamy Quote
The camera turned off, which I think it was supposed to do.
camera, firmware, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
k30 Firmware Problem / Now camera won't turn on aniro Troubleshooting and Beginner Help 7 11-27-2013 02:11 AM
K-5 won't turn on sophie100 Pentax K-5 16 06-01-2013 02:16 PM
K-x won`t turn on Rick43 Pentax DSLR Discussion 6 03-25-2012 04:26 PM
K5 won't turn on! ozlizard Pentax K-5 10 03-14-2012 02:35 PM
Ricoh camera won't turn on after batteries installed penney General Talk 4 07-26-2009 07:13 PM
All times are GMT -7. The time now is 03:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
