Did anyone have a look at the EXIFs that I posted in Dropbox ? By comparing Steeve EXIF and mine, many interesting properties can be seen there :
- new features such as:
- Orientation: Horizontal (normal)
- Roll Angle: -8 (is it degree units? To be checked)
- Pitch Angle: -25
- useful data such as:
- Sensor Size: 7.576 x 5.682 mm (This is bigger than 7.44 x 5.58 mm indicated in DPreview specifications but perhaps in includes additional dimentions for SR. Pentax Q7: Digital Photography Review)
- DSP Firmware Version: 1.01.21.08 (check the sub-sub numbers :-))
- Camera Temperature: 27 C (useful to derive the noise, lower is better, but I did not check accuracy yet)
- Scale Factor To 35 mm Equivalent: 4.6
- Circle Of Confusion: 0.007 mm
- Field Of View: 4.5 deg
- Light Value: 10.7 (this appears only in Steve picture made with 02, does not appear in mine made with a manual focus 100mm macro lens)
- unclear data such as:
- SR Half Press Time: 4.25 s or longer
- Image Size: 4064x3000 (what are those 64 more colums ? Cannot be for SR as there are no additional lines)
ExifTool Version Number : 8.40
File Name : IMGP2562.DNG
Directory : .
File Size : 18 MB
File Modification Date/Time : 2013:12:24 12:04:24+01:00
File Permissions : rw-r--r--
File Type : DNG
MIME Type : image/x-adobe-dng
Exif Byte Order : Little-endian (Intel, II)
Make : PENTAX
Camera Model Name : PENTAX Q7
Orientation : Horizontal (normal)
Software : PENTAX Q7 Ver 1.01
Modify Date : 2013:12:24 12:04:23
Artist :
Image Width : 4064
Image Height : 3000
Bits Per Sample : 12
Compression : Uncompressed
Photometric Interpretation : Color Filter Array
Strip Offsets : 182620
Samples Per Pixel : 1
Rows Per Strip : 3000
Strip Byte Counts : 18288000
X Resolution : 300
Y Resolution : 300
Planar Configuration : Chunky
Resolution Unit : inches
CFA Repeat Pattern Dim : 2 2
CFA Pattern 2 : 0 1 1 2
CFA Layout : Rectangular
Black Level Repeat Dim : 2 2
Black Level : 0 0 0 0
White Level : 3983
Default Scale : 1 1
Default Crop Origin : 0 0
Default Crop Size : 4000 3000
Bayer Green Split : 0
Anti Alias Strength : 1
Active Area : 0 0 3000 4000
Subfile Type : Reduced-resolution image
Primary Chromaticities : 0.64 0.33 0.3 0.6 0.15 0.006
Y Cb Cr Coefficients : 0.299 0.587 0.114
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/40
F Number : 0.0
Exposure Program : Aperture-priority AE
Date/Time Original : 2013:12:24 12:04:23
Create Date : 2013:12:24 12:04:23
Flash : Off, Did not fire
Focal Length : 100.0 mm
Sensing Method : One-chip color area
Custom Rendered : Normal
Exposure Mode : Auto
Focal Length In 35mm Format : 460 mm
Scene Capture Type : Standard
Subject Distance Range : Unknown
Lens Info : 0mm f/0
Lens Make :
Lens Model :
DNG Version : 1.1.0.0
DNG Backward Version : 1 1 0 0
Unique Camera Model : PENTAX Q7
Color Matrix 1 : 2.035919189 -1.353286743 -0.1195220947 0.1526031494 0.6324768066 0.2670898438 0.102722168 0.00798034668 0.5067596436
Color Matrix 2 : 1.299453735 -0.5593261719 -0.1107177734 -0.1878814697 1.013946533 0.2026824951 -0.006423950195 0.1232910156 0.4918823242
Analog Balance : 1 1 1
As Shot Neutral : 0.6168674699 1 0.5300207039
Baseline Exposure : -0.5000076295
Baseline Noise : 1
Baseline Sharpness : 1
Linear Response Limit : 1
Pentax Version : 10.6.1.0
Pentax Model Type : 3
Preview Image Size : 640x480
Preview Image Length : 10272
Preview Image Start : 37022
Pentax Model ID : Unknown (0x12f7a)
Date : 2013:12:24
Time : 12:04:22
Quality : RAW
Flash Mode : Off, Did not fire; Internal
Focus Mode : Manual
AF Point Selected : Unknown (0)
ISO : 400
Exposure Compensation : 0
Metering Mode : Multi-segment
Auto Bracketing : 0 EV, No Extended Bracket
White Balance : Auto
Saturation : Normal
Contrast : Med High
Sharpness : Med Hard
DSP Firmware Version : 1.01.21.08
Effective LV : 7.2
Picture Mode : Aperture Priority, Off-Auto-Aperture; 1/3 EV steps
Drive Mode : Single-frame; No Timer; Shutter Button; Single Exposure
Sensor Size : 7.576 x 5.682 mm
Color Space : sRGB
Image Area Offset : 0 0
Raw Image Size : 4000x3000
Preview Image Borders : 0 0 0 0
Lens Type : Unknown (21 0)
Camera Temperature : 23 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0
Image Tone : Bright
SR Result : Stabilized
Shake Reduction : On (7)
SR Half Press Time : 4.25 s or longer
SR Focal Length : 0 mm
Shutter Count : 345
Faces Detected : 0
Face Position : 0 0
Hue : Normal
White Balance Auto Adjustment : On
Tungsten AWB : Subtle Correction
Dynamic Range Expansion : Unknown (0 2 0 0)
World Time Location : Hometown
Hometown DST : No
Destination DST : No
Hometown City : Paris
Destination City : Paris
High/Low Key Adj : 0
Fine Sharpness : Off; Normal
High ISO Noise Reduction : Auto; Active (Medium)
Monochrome Filter Effect : None
Monochrome Toning : None
Face Detect : Unknown (12); 0 faces detected
Face Detect Frame Size : 0 0
Shadow Compensation : Unknown (2 4)
Cross Process : Off
Distortion Correction : Off
Chromatic Aberration Correction : Off
Bleach Bypass Toning : Off
Black Point : 111 111 111 110
White Point : 13280 8192 8192 15456
AE Exposure Time : 1/72
AE Aperture : 0.1
AE ISO : 3805
AE Xv : -7.875
AEB Xv : 5.5
AE Min Exposure Time : 352.1
AE Program Mode : Unknown (144)
AE Max Aperture : 0.1
AE Max Aperture 2 : 0.1
AE Min Aperture : 0
AE Metering Mode : [7]
Flash Exposure Comp Set : +5.5
Manufacture Date : 2013:06:14
Production Code : 2.1
Internal Serial Number : 10842
Power Source : Body Battery
Body Battery State : 1
AF Predictor : 384
AF Defocus : 2
AF Integration Time : 448 ms
AF Points In Focus : None
WB Shift AB : 0
WB Shift MG : 0
Serial Number : 4706990
Source Directory Index : 0
Source File Index : 0
Level Orientation : Horizontal (normal)
Roll Angle : -8
Pitch Angle : -25
Contrast Detect AF Area : 0 0 0 0
Cross Process Params : 0 0 0 0 0 0 0 0 0 0
Calibration Illuminant 1 : Standard Light A
Calibration Illuminant 2 : D65
CFA Pattern : [Red,Green][Green,Blue]
Image Size : 4064x3000
Lens ID : Unknown (21 0)
Preview Image : (Binary data 10272 bytes, use -b option to extract)
Shutter Speed : 1/40
Circle Of Confusion : 0.007 mm
Field Of View : 4.5 deg
Focal Length : 100.0 mm (35 mm equivalent: 460.0 mm)
