02-05-2014, 07:25 AM   #1
when Santa Claus looks pink...
In the last 1 1/2 years with my Q I have always been unhappy with the rendering of "red" under artificial light with my Q, which is often shifted to magenta. Especially in christmas time, this is extremely annoying to me, as it means that for example Santa Claus can often look like dressed in pink instead of the classic red. Unfortunately, even with RAW I haven't been able to fix that problem. The only thing that helps is the usage of the flash to change the lightning situation. Has anybody else made the same experience under artificial light, and does anybody know if the Q7 would be better in this respect?
Thanks for any help!
Christian
02-05-2014, 08:15 AM   #2
Bcrary3's Avatar
Does the Q have a white balance mode?
If so, you can play around with the WB and see if it works out, another thing you could do is shoot in RAW and then go into Adobe Photoshop, open photos with CameraRAW and manually adjust the WB either using the presets or a custom one.
02-05-2014, 08:40 AM   #3
Thanks for your reply. I have already tried this, but it doen't help either. All other colours will only look odd but the reds remain pink.
I rather seems to be an issue of the sensor (more red than the sensor can handle), or a question of image processing in the camera.
02-05-2014, 08:41 AM   #4
6BQ5's Avatar
I think it's a characteristic of the modern Pentax. My K-30 has a rough time with reds too. They get shifted to different hues or some unnatural saturation. I shoot in RAW so I can correct for this but it is noticeable. Maybe it's part of their algorithm where they had to give up red rendering for something else?
02-05-2014, 09:54 PM   #5
Bcrary3's Avatar
Hmmm... Perhaps adjusting saturation/vibrancy would help?
02-06-2014, 01:49 AM   #6
QuoteOriginally posted by 6BQ5 Quote
Thanks, maybe that explains why I like their rendering of a blue sky more than on my Canon DSLR. It has also been my impression that the general Pentax-rendering of red colours can have a small shift towards magenta, but it is usually still "ok" with my Q, at least under neutral daylight, and I really like their rendering of landscapes and the possibility to attach a polarizer.
However, for lowlight photography with the Q, this is another issue for me beside the small sensor and the slow standard zoom (especially because my Canon S110 seems to be much better in this respect...).
camera, claus, colour shift, light, mirrorless, pentax q, pentax q10, pentax q7, pink, q10, q7, red, santa, santa claus
Not Work-Safe Greetings from Santa Claus Nick Model Post Your Photos! 6 01-02-2013 04:42 AM
Not Work-Safe Santa Claus is comin to town:) janstew Photo Critique 11 12-24-2011 01:37 PM
when i bounce to ceiling, the pic looks unplesant. liukaitc Flashes, Lighting, and Studio 30 05-30-2011 06:22 PM
Looks like they lied when they said the Body Scanners couldn't save images MRRiley General Talk 17 11-19-2010 07:29 AM
Santa Claus Parade shots pentkon52 Photographic Technique 4 12-11-2007 12:08 PM
All times are GMT -7. The time now is 10:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
