02-07-2014, 03:11 AM   #1
diffraction vs depth of field for Q
I have a question for more veteran Q users. If one were taking a photo of a landscape and wanted maximum depth of field would you shoot at f7 or f8 or just shoot at f4 to prevent diffraction. As I understand it diffraction starts getting bad around f5.6. Lets say you were using the 02 lens and it's said to be sharpest at f4 would that be enough dof for a vast landscape or would you opt to stop down further? Thanks for any help or insights into this.
02-07-2014, 05:10 AM   #2
baro-nite's Avatar
f/5.6 is still reasonable to use. I'd say it's roughly equivalent to f/16 on APS-C for a similar image, in terms of both diffraction and DOF.
02-07-2014, 05:37 AM   #3
I find it depends on the lens. With the 02, f:4 to f:5.6 is good. A couple of my other non-Q adapted lenses are best at f:5.6 to f:8. DOF with the Q is pretty deep. You should get all the DOF you need at 5.6.
02-07-2014, 01:44 PM   #4
6BQ5's Avatar
If you are shooting wide angle landscapes then I would say shoot as wide open as you can. The has plenty DoF for landscapes due to the smaller sensor size. Check out this review of the 01 lens:
Pentax-01 Standard Prime 8.5mm f/1.9 (Pentax Q) - Review / Lens Test - Analysis
I would say that maximum resolution is achieved starting at f/2.8 before it starts to fall at f/4. Maybe f/3 is ideal? I don't know. You'll have to try it for yourself and see what you think. Diffraction became very evident to me as I started going beyond f/4. Yes, I seem to get more DoF but at the expense of overall sharpness - at least to my eye.
The 02 lens is similar:
Pentax-02 Standard Zoom 5-15mm f/2.8-4.5 (Pentax Q) - Review / Lens Test - Analysis
I posted a landscape shot made with the 01 at f/2.8 here:
https://www.pentaxforums.com/forums/136-pentax-q/172196-lets-share-shots-q-233.html#post2680170
If your Q is overwhelmed with light then lower the ISO and turn on the ND filter. Building a switchable ND filter into the Q system was a stroke of genius from Pentax in my book
02-07-2014, 09:12 PM   #5
Thanks for the info and tips. Yeah that ND filter is really handy so you don't have to stop down as much in bright conditions. I thought of that too and have used it a few times. Looks like even 2.8 on the prime is suitable for landscape. I saw some really nice Q photos on flickr by various people that shot at f7 and f8 so I was just wondering if there was any benefit there or they just did that cause it was so bright out. Check out this stunning Q shot taken at f7.1. Wonder why they chose those settings here since a sunset isn't usually super bright.
02-07-2014, 09:30 PM   #6
Multi-coated's Avatar
Understanding Your Camera’s Hyperfocal Distance <- Handy calculator on site.
I thinking that there's not generally a lot of point in going past... f/4-4.5 even in very bright conditions. There's the ND filter and the electronic shutter with max of 1/8000. Easy enough to avoid diffraction.
02-07-2014, 09:38 PM   #7
6BQ5's Avatar
The shooter in the ocean / beach landscape above has some shoreline that is very close to him. He wanted that to be in focus. Many landscape shots tend to have the camera pointed slightly upward so the closest thing to the camera (which is near the bottom of the shot) is actually pretty far away. It's so far away that even at f/2.8 it will come into focus. The sand in the shot above looks like it may only be 10 feet away and the shooter may have crouched down to capture it.
It would be great to have taken this shot twice - once at f/2.8 and once at f/8. When you compare the shots side by side you will pick out what would be the diffraction. You would also see the sand be a bit softer too.
camera, depth, depth of field, diffraction, diffraction vs depth, f4, field, landscape, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Nature Shallow depth of field Darrell Raw Photo Critique 21 11-11-2013 03:57 AM
Depth of field tcheetham Troubleshooting and Beginner Help 4 09-30-2013 12:05 PM
Misc WIDE depth of field tessfully Post Your Photos! 10 10-31-2012 05:44 AM
Macro: Depth of Field vaper Pentax SLR Lens Discussion 16 09-22-2012 07:44 AM
Depth of Field for Dummies Paleo Pete Photographic Technique 5 07-12-2012 10:44 AM
All times are GMT -7. The time now is 01:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
