Originally posted by MykeBatez Awesome! Thanks for the links. It's rather daunting delving into all the old lenses and trying to figure out what the crop factor will turn them into on the Q.
The help is much appreciated, and I bet I'll pick up one of those soon. Probably starting with the supertele and then filling in the closer range with the 200-400mm.
Also it's a good point about using them on a Pentax DSLR. I might get a K50 towards the end of this year and I'd still get to use them then
One thing to consider, and my situation is different, I have 55 K and M42 lenses, so my curiosity in C Mount is super small. The 25/1.4 I got is 1/4 the size and weight of either my tamron 24/2.5 or the kiron 24/2 .and it is a full stop faster than either of my other 24mm lenses. Plus a C mount adaptor is much smaller than the K-Q adaptor
But once you go to tele lenses, I see no point unless I happen to come across a C mount that really shines, because once you get to the 100mm+ focal length! the front element size required for the aperture dominates lens size
Also, for old pentax lenses, there are K to canon, M42 to canon, and for all mirror less cameras made by everyone else, there are likely K&M42 adaptors, you don't need to stay with pentax to use the lenses, but once you try a pentax camera, and I suggest do this first, then play with the canikons you'll decide pretty quickly that pentax has a lot to offer
